Oklahoma Tractor Man
- Joined
- Apr 11, 2022
- Messages
- 1
- Tractor
- New Holland TC35D
Have a TC35D, does not want to start; this is getting old. Just replaced solenoid to pump (cutoff). This is the 3rd. They go bad. Any rate, tractor worked for about a week an then stopped! I checked solenoid and it works however, no voltage. same with starter. When jumped using the tractor's battery (voltage applied to where plugs into starter) started like a champ. What does starter relay send voltage to? Could it be that or Micro (safety) switches? Ignition switch? The seat is jumped (bypassed). Honestly, have yet to take off steering cover and check breakers. Just looking for ideas if blown fuse not case. Basically: No voltage to fuel pump solenoid or starter when ignition switch engaged.
