TC 35A PTO stuck on, tractor will not start
   / TC 35A PTO stuck on, tractor will not start #1
boatyard
western MASS.
2005 New Holland TC35A
I was splitting wood with a PTO pump powered splitter and just turned the tractor off without disengaging the PTO. Now I can not move the handle to disengage the PTO and of course the tractor will not start with the PTO still engaged. How do I fix this? Thanks.
   / TC 35A PTO stuck on, tractor will not start #2
Can you undo the splitter input shaft connected to PTO manually? See if you can turn the PTO shaft by hand while tractor is OFF?
I tried that and nothing changed. I just spoke with someone at the dealer and she said I need to release the hydraulic pressure and then the lever should move. SHe did not know how to do that on my tractor. Any thoughts on how to do that?
OK problem solved. I did something that I hate to do. I pushed much harder. It made a popping sound, the lever moved and the tractor started. Note to self; never turn off the tractor without disengaging the PTO first.
   / TC 35A PTO stuck on, tractor will not start #5
Do you know if you PTO is live (dual clutch) or independent and hydraulically activated? in the case of dual clutch is all mechanical engagement. so when you said tried, did you mean you disconnected the implement input shaft from tractor PTO splined shaft from tractor? how do you engage and disengage? lever or a switch?
   / TC 35A PTO stuck on, tractor will not start #6
I was about to suggest that , along with changing gear shifter, clutching all the way and trying. For me I have to lower the rpm, move forward and back and then try to disengage the PTO. I almost always disengage pto with engine on at the lowest RPM and clutch fully compressed. I don't have live PTO on my Ford and it is transmission driven PTO. glad you got it un-stuck.
   / TC 35A PTO stuck on, tractor will not start #7
You may not always be able to turn off the pto though before the engine shuts off.
Example - If you stall the tractor while doing something with the 3 pt
   / TC 35A PTO stuck on, tractor will not start #8
This tractor should have a independent PTO and has a wet clutch. You may need to open the PTO switch and start the machine. Then release the PTO.
   / TC 35A PTO stuck on, tractor will not start #9
Something that doesn't make sense is the PTO pump is bound to the PTO shaft even with the tractor off. The woman at the dealership was probably suggesting that you release the pressure on your splitter to allow the pump to take the torque out of the PTO drivetrain.
Anyway, you shoved the PTO lever (ouch) and accomplished the same thing.
1986 ASPT 30ft S/A Pole Trailer (A49346)
1986 ASPT 30ft S/A...
Wolverine Quick Attach Stump Grinder (A50514)
Wolverine Quick...
Skid Steer Plate Attachment (A50322)
Skid Steer Plate...
2020 Bobcat T76 R-Series (A47384)
2020 Bobcat T76...
2009 GREAT DANE 53FT REEFER TRAILER (A52141)
2009 GREAT DANE...
2013 Infiniti JX35 AWD SUV (A50324)
2013 Infiniti JX35...
