TC-35 glow plug light and more
   / TC-35 glow plug light and more #1
epic
Morristown, VT
New Holland TC-35
Hi guys, I have a 20ish year old TC-35. When I start it the glow plug light stays on for a while. Even if it is warm and I did not use the glow plugs. There is another strange symptom though which I think is related. The tractor sometimes has a loud fan belt sounding squeal. It reminds me of the screech of a 1980s VW Jetta fan belt. Whenever it squeals like this two other things happen, the glow pug light comes on and the tachometer RPMs drop even though engine RPMs do not drop. What is going on here?
   / TC-35 glow plug light and more #2
For the second issue the belt squeal;
I would assume your fan belt is slipping that runs the alternator.
It could be that the glow plugs are turning on with the engine running and the electrical load is making the belt slip.
The alternator is what is providing the tach signal for rpm, so when the belt slips the alternator is slowing down and shows as reduced rpm.
That makes sense, and I'd think changing the fan belt would not be too hard. Maybe a relay for the glow plugs or something?
   / TC-35 glow plug light and more #4
You may not need to change the fan belt. They do have a tension adjust.
   / TC-35 glow plug light and more #5
Tension belt : Fan belt dressing spray .:thumbsup::drink:
   / TC-35 glow plug light and more #6
Same belt issue with my TC29D and the belt. My belt is very loose, belt dressing spray did help but it's back again. I just need to tighten it. I just checked the factory service manual and the tach gets it's reading from the "P" lead off the alternator.
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
2018 Ford Explorer AWD SUV (A55853)
2018 Ford Explorer...
1989 25'' crosley dove tail trailer (A55787)
1989 25'' crosley...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
2018 Caterpillar 308E2 CR Midi Excavator (A55973)
2018 Caterpillar...
2014 Ford Fusion SE Sedan (A55853)
2014 Ford Fusion...
