TC 35 Died last night...
/ TC 35 Died last night... #1
DougU
Central Illinois
None yet!
I have a TC 35 I bought 1 month ago with only 49 hours. I have since just "messed" around with it and only put about 1 hour on. Haven't got my mower yet. Anyway, the other night I was taking my 3 yr old granddaughter on grandpa's big blue tractor and it died on me. I was driving along slowly and it just quit, like it had run out of gas. Tried to restart and it kept turning over but wouldn't fire. Like it wasn't getting fuel, even though it has a full tank. Kept cranking to no avail.
I went back last night to try again, pulled the parking brake on and it started right away! However, as soon as I took the parking brake off it died. When I went to restart it, now it won't even turn over. The yellow PTO light is now "on" on the dashboard, never noticed that before. The PTO is NOT engaged. It's acting like the PTO is on and therefore you can't start it. Could the "switch" be malfunctioning that tells the tractor the PTO is on, when it in fact is not? HOw might this relate to my problem with it dying. My first thought the other night was a fuel pump or filter problem. But why would it start right up again after setting for 24 hours? By the way, I have to jump to start it since the battery is now drained.
Thanks!
Doug
/ TC 35 Died last night... #2
I'd look at the seat switch....the tractor won't start if the brake switch isn't set and also the PTO has to be in 'off'. Since it died underway, I'd guess that the seat switch might have become disconnected simulating you getting up and walking away while underway. The switch is under the seat and is quite easy to check. Just pull the quick connnect and jumper the harnes and see if it starts. If so its the switch.
While your at it check the brake switch by setting the key to run and set and release the brake. The switch should go on-off. You can try the same with the PTO switch / lever.
Good Luck
Thanks for the quick response, I'll look into that..
BUt shouldn't it start as long as I have the parking brake set even though I'm not on the seat? Also, why is the PTO light on?
Thanks.
/ TC 35 Died last night... #4
Can't tie in the PTO and the Brake safety switches together, but it is one of them. In light of the PTO light being on, I'd look at the PTO Safety Switch and associated linkage. Even though your lever may be in the "PTO off" position, if the linkage has come undone the linkage may be engaging the PTO. Attached is page 1 of troubleshooting the switch.
Edited:
The PTO safety switch is also responsible for sending current to the PTO indicator dash light.
/ TC 35 Died last night... #5
Page 2. Also, diesels are not like gas engines. If it doesn't start when turning over, it won't do any good to try turning it over so much the battery dies.
Thanks for the info Chris. Where did you get the info you attached? Is this from a service manual? If so, where can I get one?
THis is my first diesel, thanks for the advice on starting. Was not aware of this.
Doug
/ TC 35 Died last night... #7
I ordered the service and parts manual over the phone. I believe the number is in the owner's manual for the tractor. I keep the service/parts manuals at home, and the owner's manual at the farm so I can't check for sure about the phone number. The manuals occasionally show up on eBay. They fit in a 3" blue binder, and are not cheap. (~$270 if my memory serves.)
Been thinking more - with the PTO engaged the switch is open and the engine should not turn over. Are you still able to crank, or does the started not energize? The attached is the troubleshooting page for the deluxe safety starting circuit.
/ TC 35 Died last night... #8
Found the receipt for the manuals - denial helped me forget I paid $314 for the manuals from:
CNH America LLC
700 State Street
Racine, WI 53404
262-636-7540
It was $66.04 for the parts manual, $230.27 for the repair manual, and $17.64 for the pretty binder on February 02, 2004.
Right now it won't even crank. PTO light is on. One of the safety switches is engaged somehow. Have moved all levers, PTO, etc. many times, no help.
Doug
/ TC 35 Died last night... #10
Also eBay has some manuals from time to time. I bought a complete set for my TC24 for well under $100. I think I paid around $70 with shipping. I saw some manuals for TC55's, 45's, and TC18/21/24 earlier today. Not sure which ones though. With my 24, there are 4 or so books. I don't have a parts book though.
/ TC 35 Died last night... #11
Doug, I believe if the PTO is engaged (or the tractor thinks it is) or if the tractor is in gear the engine will not crank. All these things are controlled by switch closures under the left operator's platform by the brakes or between the wheel and the seat. You need to look behind the left step at the brake pedals and parking brake to see if something has come loose and/or the switches are out of adjustment. I believe you can see the PTO switch better from behind the tractor looking up between the wheel and the transmission. If you can get someone to move the levers while you watch, it really helps.
The transmission switch is on the side of the transmission, so make sure it hasn't come loose.
Since you say your PTO light is ON, I doubt the transmission switch is malfunctioning. It's probably a misadjusted PTO switch or a broken wire.
What happens when these interlocks shut the tractor down is the tractor will not turn over and/or the fuel shutoff solenoid is deenergized. Once the problem is located, it will be a simple solution. The hardest part is finding it. /forums/images/graemlins/crazy.gif
/ TC 35 Died last night... #12
is your tractor a tc35/tc35d or a tc35a/tc35da? either way your PTO safety switch is disconnected- if its past a certain serial number d you have 2 safety switches in the transmission case just in front of the right rear axle- each switch has to wires coming from it. if the lower switch wires are not visibly apart the pull them both apart and re-connect them. they have very long boot on them so it is not always visible at first.
/ TC 35 Died last night... #13
One other possibility for what might be wrong (assuming that your new Class III Boomer acts the same as my 4+ year old unit).
If the battery is sufficiently worn down there will not be enough power to turn the starter but the current will be enough to blow a fuse or trip a circuit breaker. On the older units (my TC40's era) these were fuses. I believe that NH converted this particular fuse to a CB a couple years ago but that is heresay on my part; others here would probably know more.
If the PTO light is on, PTO is off and the starter will not turn I always check my fuse first.
/ TC 35 Died last night... #14
Has your tractor joined the "undead" yet?
Hi everyone and thanks for the help. Here's what happened-
Somehow the wire underneath the seat connecting the safety switch came undone. It was late at night when it happened and I couldn't see that. That is why the tractor died, but would start when the parking brake was activated. That's also why when I put it in gear and released the brake, it died again.
I reconnected the wire and it still wouldn't start. PTO light was still "on" the console. Pulled instrument cluster to get at the fuse box. The 7.5 amp fuse for the PTO was blown. Not sure what caused that, but put in new fuse and everything works great!
Happy ending and my 35 is humming along again. Thanks!
/ TC 35 Died last night... #16
WOW! Most of us only have one of those problems at a time, but you got "lucky" and got two of the problems at once. /forums/images/graemlins/tongue.gif /forums/images/graemlins/laugh.gif
Now I wouldn't want you to do anything "unsafe" and jumper around your seat switch all the time like I did. But if you were gonna do it, it would look just like the attached photo. /forums/images/graemlins/blush.gif
/ TC 35 Died last night... #17
</font><font color="blue" class="small">( Now I wouldn't want you to do anything "unsafe" and jumper around your seat switch all the time like I did. But if you were gonna do it, it would look just like the attached photo. /forums/images/graemlins/blush.gif )</font>
What a coincidence. The jumper I don't use looks exactly like that. /forums/images/graemlins/blush.gif
My dealer didn't see the non-existent jumper either. I know that because he told me "I didn't see that".
/ TC 35 Died last night... #19
</font><font color="blue" class="small">( What a coincidence. The jumper I don't use looks exactly like that. /forums/images/graemlins/blush.gif )</font>
...and you never stand up on your tractor and take your seatbelt off either. /forums/images/graemlins/smirk.gif I know a guy who used to have a TC29 and he'd hook a chain to a tree, start the tractor pulling, and then get off and take a break. /forums/images/graemlins/shocked.gif
You don't know that guy do you? /forums/images/graemlins/wink.gif /forums/images/graemlins/laugh.gif
Hey, Brad_Oatley, check out the attachment. You have to take out the instrument cluster, but it's easy as pie. /forums/images/graemlins/cool.gif
/ TC 35 Died last night... #20
Jim...keep scanning...pretty soon we'll have that whole manual in digital form !!!!! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
PowerBoss Admiral Plus 38C Ride-On Floor Scrubber/Sweeper (A59228)
PowerBoss Admiral...
Coats 1055 Direct Drive Wheel Balancer Machine (A59230)
Coats 1055 Direct...
Peterbilt 377 Semi-Truck (A61306)
Peterbilt 377...
2011 Ford F450 Diesel with Just 156638 Miles (A56435)
2011 Ford F450...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
UNUSED FUTURE EQUIPMENT SEAT (A60432)
UNUSED FUTURE...
