TC 33D hydro problem alert
   / TC 33D hydro problem alert #1
dylan
ottawa, canada
Toolcat B series
Hi all
I'm not sure if this has been posted before but here is a problem to be watching for on the tc 33d.
The two hoses that go to the tranny cooler seem to split open around 400 hours. My neighbours blew out at 400 hrs and mine went at 445 hrs. They are easily replaced but get your dealer to order some in advance. Appearently the new replacements are tougher and will last longer.
Dylan
   / TC 33D hydro problem alert #2
It's not just the 33D, it's all Class II Boomers and it can happen a lot sooner than 400 hours. I replaced mine at 181.3 hours after I opened the hood while the engine was running and saw the hoses were the size of small hernias!
Here's a link to an old thread. I think there were even earlier ones. Some people found out about it before they broke. Thanks for reminding us to keep an eye on it. /forums/images/graemlins/smile.gif
   / TC 33D hydro problem alert #3
Thank goodness the Class I boomers have a different hose /forums/images/graemlins/grin.gif
Although, the clamps do require a little tightening every now and then on the Class I
   / TC 33D hydro problem alert #4
And mine broke at 5 hours. Way to go New Holland! Hasn't done anything in years to fix the problem.
   / TC 33D hydro problem alert #6
Yep! Mine broke at 5 hours and then had to replace one of them again at 65 hours due to cracks. New Holland, fix the problem!
   / TC 33D hydro problem alert #7
Are you talking about the small oil cooler on the front just above the battery?
Sherpa
   / TC 33D hydro problem alert #8
<font color="blue">Are you talking about the small oil cooler on the front just above the battery? </font>
Yes.
   / TC 33D hydro problem alert #9
Checked mine and they look OK. I tighten down on the clamps a little. Takes an 8MM wrench.
Sherpa
   / TC 33D hydro problem alert #10
Just to be sure...You checked them with the engine running, right?
2019 Kenworth T880 T/A Wet Kit Day Cab Truck Tractor (A50323)
2019 Kenworth T880...
LOAD OUT INFORMATION (A53084)
LOAD OUT...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
2015 Chevorlet Silverado LT Z71 (A50120)
2015 Chevorlet...
2015 DODGE RAM...
