Grading TC 33 with 6' box blade??
   / TC 33 with 6' box blade?? #1
DougU
Central Illinois
None yet!
TC 33 with 6\' box blade??
I have a TC33 and need to purchase a box blade. I would like to go with a 6' so it covers my tire tracks, but am concerned whether the 33 can handle it. THe next smaller size is 5'. Opinions?
   / TC 33 with 6' box blade?? #2
Re: TC 33 with 6\' box blade??
I have no first hand experience with a TC-33 with a 6 foot box blade, but that seems quite wide for that tractor. I have been shopping for a 6 foot box blade for my TC-35. As you stated a 6 ft. box blade will barely cover my tracks. I do finish work near houses and driveways so I wanted something wider. Bush Hog makes their SBX line in 6 inch increments. So I'm looking at a SBX-780, which is a six and a half footer. You may want to consider a five an a half footer. The Bush Hogs are a little more expensive, but are built better than some of the cheaper brands. http://www.bushhog.com/turftoc.html
   / TC 33 with 6' box blade?? #3
I have a 5 1/2 foot box blade on my TC33. They were real popular for the 8Ns. Its perfect for the TC33.
Sherpa
   / TC 33 with 6' box blade?? #4
I have a 60" on my DX33. It covers the tire tracks, but is a little narrower than the sidewalls. If I want to blade next to buildings, I pull the pins on the sway bar links, push the blade over a few inches and reinstall pins. Only takes a minute. The smallest blade that will fit makes the best use of engine torque.
   / TC 33 with 6' box blade?? #5
i have a tc30 (30HP) and i have no problem with a 6' box. Don't go to fast and it'll work great for you.
   / TC 33 with 6' box blade?? #6
There are also some companies out there that make a 66" box blade.
   / TC 33 with 6' box blade?? #7
Doug,
I have a TC33DA with the Titan Multi Trac turf tires and a 60" Woods box blade. I purchased the blade primarily for gravel driveway maintenance. I have yet to do any heavy dirt moving but have had the box full with gravel with no problems. The 60” BB is about ½” wider than the tires so it is difficult to work the edge of a road or cutting line.
I thought I was purchasing a 66" box blade but I was delivered a 60" blade. The price I got was good for a name brand hinged tailgate blade so I kept it. I would believe the 33 could handle the 66” BB. Not sure about the 72”. If I would do it again, I would definitely get the 66” BB.
…Derek
   / TC 33 with 6' box blade?? #8
I have a CaseIH DX33 (basically the same as a NH TC33D)with a 72" boxblade and it handles it just fine. Even with the scafiers down I find that it runs out of traction before it runs out of power.
Thanks for everyones replies! They are very helpful. I'm a little confused though, as to how the 66" blade would cover my tire tracks. My measurements should it would take at least 72". My TC33 has 17.5L-24 Industrial tires. Are those the standard tires? I bought the unit used this year, with 50 hours.
   / TC 33 with 6' box blade?? #10
My TC29D which is suppose to be the same tire I thought or my book says so is 15-19.5. Looks to me like there has been a change or I sure would look further into it to make sure your fronts match up.
murph
2014 Ford F150 XL Pick Up (A47384)
2014 Ford F150 XL...
Ford 1710 Tractor (AS IS) (A50774)
Ford 1710 Tractor...
198367 (A51243)
198367 (A51243)
UNUSED JCT SKID STEER QUICK ATTACH 84" DOZER BLADE (A51244)
UNUSED JCT SKID...
20' One Trip Shipping Container (A50514)
20' One Trip...
LANDPRIDE RCR1242 - 4' ROTARY MOWER (A51243)
LANDPRIDE RCR1242...
