TC 33 - Clutch adjustment?
   / TC 33 - Clutch adjustment? #1
global312
My TC 33 (HST) has had a problem with shifting the levers from neutral since new? I sometimes have to push and release the clutch 3 or 4 times to shift from neutral. I should have had this fixed under warranty, but the problem doesn't occur all of the time and I just let it go. I did mention this to the dealer and he said the linkage probably needed to be adjusted. Has anyone else had this problem? How can I fix this?
   / TC 33 - Clutch adjustment? #2
If it does not want to go into gear just let up on the clutch, push the hydrostat petal slightly and push it into gear without using the clutch. It works every time on mine. Not necessary to clutch to put the hydro into gear.
2009 Volvo VHD Tandem Dump Truck, VIN # 4V5KC9EF19N270338 (A51572)
2009 Volvo VHD...
2005 NEW HOLLAND DC95WT CRAWLER DOZER (A51406)
2005 NEW HOLLAND...
2018 JLG G5-18A (A50123)
2018 JLG G5-18A...
2004 HYUNDAI V12530152-AJS 53FT DRY VAN TRAILER (A53426)
2004 HYUNDAI...
200722 (A51247)
200722 (A51247)
2019 Caterpillar 950M Articulated Wheel Loader (A51691)
2019 Caterpillar...
