TC 33 - Clutch adjustment?
   / TC 33 - Clutch adjustment? #1
global312
My TC 33 (HST) has had a problem with shifting the levers from neutral since new? I sometimes have to push and release the clutch 3 or 4 times to shift from neutral. I should have had this fixed under warranty, but the problem doesn't occur all of the time and I just let it go. I did mention this to the dealer and he said the linkage probably needed to be adjusted. Has anyone else had this problem? How can I fix this?
   / TC 33 - Clutch adjustment? #2
If it does not want to go into gear just let up on the clutch, push the hydrostat petal slightly and push it into gear without using the clutch. It works every time on mine. Not necessary to clutch to put the hydro into gear.
2003 GMC C5500 DUMP TRUCK (A51406)
2003 GMC C5500...
7033 (A51691)
7033 (A51691)
2009 Chevrolet Trail Blazer SUV (A51694)
2009 Chevrolet...
2013 KENWORTH T800 DAY CAB (A53426)
2013 KENWORTH T800...
Kubota Salt-Spreader (A52384)
Kubota...
2007 International 4300 Cab and Chassis Truck (A51692)
2007 International...
