TC-30 won't start!
   / TC-30 won't start! #1
shrike
Roseville, PA
NHTC-30
TC-30 won\'t start!
Fellow TBN'ers, Yesterday I could not start my brand, spanking new TC-30. I got it tuesday evening and drove it that night and the next morning. After it sat idle for a few hours I went to start it up again and "Nothing"! The panel lights worked, the headlights and taillights worked, but no power to the starter, not even a "click". Checked tractor in neutral, brake on, PTO not engaged (why should it be, I didn't use it?) I checked the seat switch wires, the fuse wire to the starter and then crawled underneath to check the PTO wires and there was the problem. The mid-PTO showed that it was engaged! How'd that happen? Maybe when I climbed out of the seat I inadvertently engaged it. Pushing down on the lever engages the PTO, pulling it up disengaes the PTO but the decal near the lever showed just the opposite! Solution; disengage mid-PTO, reverse the decal and start engine!
Fellow TBN'ers, I would like to take this opportunity to thank all of you for posting to TBN. I have learned a great deal from all of you (like possible solutions to the above little problem) and I know that I will continue to use TBN as a primary source for information on CUT's .
sincerely,
Bruce Launius
Roseville, PA
NHTC-30; BH1846 FEL; BH2101PHD; BB; LR; RB
   / TC-30 won't start! #2
Re: TC-30 won\'t start!
I'll second that.. last night went out to start my TC35D.. click.. click.. click.. what? my battery's almost dead? Hooked up the battery charger.. checked the voltage.. set it on engine start. Tried to start.. nothing.. no clicking.. dashlights on.. wiggled the gear shift.. jumped up & down on the seat.. still nothing. What the @#$%.. oh.. from TBN.. fuse problem.. and also from TBN I knew exactly where the fuses are.. two screws later behind the instrument panel.. the 7.5 amp fuse had blown. Picked one up today.. left the battery charger on overnight until I get home from work. I had not done any battery maintenance(for 3 years).. and the cells were dry as a desert.. I'm hoping it'll take a charge & come back to life.
Thanks to TBN.. I went from Panic mode.. to fix it mode right away. I'll be hitting 750 hours on my workhorse this weekend.. my farm neighbor has a couple large oaks & 1 big cherry tree dead next to his field.. he just finished harvesting his winter wheat(late from all the rain).. so he wants me to get at them before he plants again. I save the big logs and make beams & lumber from them. Thanks guys!!
   / TC-30 won't start! #3
Bruce, first couple days I had my TC35, it took some acclamating.... the safety features that I didn't have on my 8n gave me a new appreciation for those safety mistakes I was making when I was using the old tractor. Hope you end up liking your NH as much as I like mine... I haven't found one thing I don't like yet after 2 months of pluggin' away /forums/images/graemlins/smile.gif
Right, EagleEye, The last time I operated a "real" tractor, ya just climbed on, put the clutch in, turned the key on and hit the starter button! /forums/images/graemlins/smile.gif Things have changed a bit. /forums/images/graemlins/grin.gif
Bruce
2020 Ex Mark Lazer Z 60in Zero Turn Commercial Mower (A55973)
2020 Ex Mark Lazer...
2022 Ford F-450 Super Duty STX Pickup Truck, VIN: 1FT8W4DT2NEC20764, Crew Cab, 4x4, Fx4 Off Road, (A59076)
2022 Ford F-450...
Heavy Duty 44in Excavator Rake (Fits CAT 305) (New/Unused) (A59225)
Heavy Duty 44in...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
METAL STORAGE RACK (A52708)
METAL STORAGE RACK...
MASSAGE CHAIR (A58214)
