TC-30 ENGINE BLOCK AND CLUTCH ASSEMBLY CRACKED!!!
   / TC-30 ENGINE BLOCK AND CLUTCH ASSEMBLY CRACKED!!! #1
TRACTORAL
HI ALL,
I OWN A 2004 NH TC-30. HAVE SERVICED IT REGULARLY AS PER INSTRUCTIONS. IT HAS A STOCK BACKHOE ON IT. IT HAS ONLY 438 HOURS ON IT AND IS OUT OF WARRANTY.......HAVE USED IT AROUND MY HOUSE MOVING STONE AND DOING VERY MINOR DIGGING. I USE IT MOSTLY FOR HAULING FIREWOOD.
JUST THE OTHER DAY, WHILE GETTING OFF THE MACHINE, I NOTICED OIL DRIPPING FROM THE LEFT SIDE OF TRACTOR. UPON INSPECTION I SAW A CRACK IN THE ENGINE BLOCK NEAR WHERE IT CONNECTS TO THE TRANNY. I HAD MY DEALERSHIP TAKE IT AND GO OVER IT. THEY FOUND THAT CRACK AND A CRACK IN THE CLUTCH HOUSING ASSEMBLY. OF COURSE THEY SAID THEY NEVER SAW THIS BEFORE BUT I KNOW BETTER. AFTER GOING ONLINE TO A BUNCH OF SITES I SEE THIS IS SOMEWHAT COMMON. DOES ANYONE OUT THERE HAVE ANY EXPERIENCE WITH THIS, OR KNOW OF ANYONE THAT HAD THIS HAPPEN??? MY QUOTE FROM N.H. IS EXACTLY $10,656.83 TO REPLACE/REPAIR SAME.
   / TC-30 ENGINE BLOCK AND CLUTCH ASSEMBLY CRACKED!!! #3
That's some tough luck..I feel for you, and hope somehow things work out for you. Probably wouldn't hurt to make copies of all similar failures you've found and try to get NH to talk with you.
Good luck
(BTW all caps is frowned upon on forums, it's how we yell)
THAT'S WHAT I AM DOING. TRYING TO GET AS MUCH INFORMATION ON THIS AND OTHER SITES. YES, IT SUCKS.
I TYPE IN CAPS CAUSE I'M LAZY AND DON'T WANT TO USE THE SHIFT BUTTON ALOT.
SORRY.
BE WELL,
AL
   / TC-30 ENGINE BLOCK AND CLUTCH ASSEMBLY CRACKED!!! #5
I am the one who started the thread "brother in laws TC 30 ready to crack in half" If you would like, you may PM me and perhaps I can get you and my brother in law in touch with one another. Good Luck, Ryan.
1989 Ford FT900 T/A Cab and Chassis Truck (A51692)
1989 Ford FT900...
Zerex 50/50 Anti-freeze (A53117)
Zerex 50/50...
2018 Dodge Charger Sedan (A51694)
2018 Dodge Charger...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
FAE UML/SSL 150 VT BL HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
City of Buckhannon - Power Curber 5700 (A52384)
City of Buckhannon...
