TC-29D Hydraulic leak ?
   / TC-29D Hydraulic leak ? #1
brin
Super Member
Georgia - Mt. Vernon by The Store just 5 miles eas
I have done a search and found nothing that applies.
When I park my tractor ( TC-29D ) and it sits for a few days , I look underneath and see 3 spots of hydraulic oil on the floor under the tractor - maybe a teaspoon each - one spot just behind the engine, and 2 spots under the transmission - but no leaks there. So I am thinking it could be leaking up front - like under the power steering fluid tank where I see some build up at the bottom and then running back and just dropping down in those 3 spots.
I do my own servicing but beyond that I tend to go above my pay grade...any ideas on where to look or what it might be ?
Thanks in advance.
   / TC-29D Hydraulic leak ? #2
I know that yours is the next size bigger than my 24DA but I had a mysterious oil leak (hydro fluid) that turned out to be the seal on the main input shaft for the transmission/hydro pump. I'm certain that the cause was the bolts holding the two sections of tractor together were coming loose (engine to transmission/axle housing). Its a wonder the tractor did'nt split apart on its own. I initially noticed oil dripping from what looked like a small cotter pin in a drain hole in the bottom of the clutch/flywheel housing.
As you said though, oil leaks can originate anywhere and show up somewhere else. You might try using some dye and a black-light (UV) and see if it shows up. Of course you would want to to one section of oil at a time (engine oil first, then if nothing after some operation time try adding to hydro oil, etc.). I bought the dye and a LED flashlight with a UV light included at NAPA for pretty cheap.
I now have a new leak coming from the front axle where the two sections are bolted together in the center of the axle. If I open the fill/dipstick plug after its been in operation for a while a fair amount of pressure comes out and then the leak subsides. Why NH did not put a vent in the front axle is beyond me? I guess that will be my next project.
Good luck, hope you don't have to go through what I did!
   / TC-29D Hydraulic leak ? #3
Remove the shroud under steering wheel ( two piece cover) and check your steering hydraulic valve. Bet you that is where your leak is.
Mega Me and dqdave1...Thanks a bunch for the advice, I will check all you have mentioned this weekend and let you know what I find....Thanks again, I appreciate the help.
2025 K4230G UNUSED Metal Storage Shed (A53117)
2025 K4230G UNUSED...
Quick Attach EZ Axe Skid Steer Tree Shear (A53473)
Quick Attach EZ...
2020 CHEVROLET SILVERADO (A53843)
2020 CHEVROLET...
Auger for mini skid steer (A53421)
Auger for mini...
2015 Ford Taurus AWD Sedan (A51694)
2015 Ford Taurus...
2011 Mercedes Benz Sedan (A51694)
2011 Mercedes Benz...
