Tc 29 will not rev up!
   / Tc 29 will not rev up! #1
porkchop401
Coushatta, LA
My tc29 started smothering down so I replaced the fuel filter after bleading the system at the pump and injector fittings it will not rev up . It will spit fuel from the injector line fitting and will lightly miss while the line is loose but it will not rev up. The linkage is connectted I am puzzled. Mike
   / Tc 29 will not rev up! #2
Is the air filter ok?
   / Tc 29 will not rev up! #3
Have you tried blowing air backwards through the fuel line? I had a similar problem where I went through all the usual exercises of replacing filters, etc., and none of those seemed to help. It turned out there was some crud clogging the fuel pick-up in the tank. Blowing high pressure air back through the fuel line blew it out, and everything worked fine afterward. After getting the crud dislodged, I drained the tank and saw that there was a bunch of debris in there.
   / Tc 29 will not rev up! #4
is she maybe sucking air?
2017 CATERPILLAR 299D2 SKID STEER (A51246)
2017 CATERPILLAR...
2021 MACDON C3812 LOT IDENTIFIER 34 (A53084)
2021 MACDON C3812...
2024 JOHN DEERE 461R LOT IDENTIFIER 58 (A53084)
2024 JOHN DEERE...
Year: 2012 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 61,276 Plate: Body Type: 4 (A50324)
Year: 2012 Make...
2001 KINCAID PRO-SERIES 1200V2 HYDRO SEEDER (A51406)
2001 KINCAID...
Massey Ferguson 231 Tractor with Loader (A51573)
Massey Ferguson...
