Tc 29 will not rev up!
   / Tc 29 will not rev up! #1
porkchop401
Coushatta, LA
My tc29 started smothering down so I replaced the fuel filter after bleading the system at the pump and injector fittings it will not rev up . It will spit fuel from the injector line fitting and will lightly miss while the line is loose but it will not rev up. The linkage is connectted I am puzzled. Mike
   / Tc 29 will not rev up! #2
Is the air filter ok?
   / Tc 29 will not rev up! #3
Have you tried blowing air backwards through the fuel line? I had a similar problem where I went through all the usual exercises of replacing filters, etc., and none of those seemed to help. It turned out there was some crud clogging the fuel pick-up in the tank. Blowing high pressure air back through the fuel line blew it out, and everything worked fine afterward. After getting the crud dislodged, I drained the tank and saw that there was a bunch of debris in there.
   / Tc 29 will not rev up! #4
is she maybe sucking air?
2025 New/Unused LandHonor 13,000lb Electric Winch (A51573)
2025 New/Unused...
2020 Mclanahan 150 TPH USP Wash Plant (A52377)
2020 Mclanahan 150...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
UNUSED X-STAR 750 GALLON FUEL TANK (A51247)
UNUSED X-STAR 750...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A51573)
(1) HD 24ft Free...
UNUSED CHERY INDUSTRIAL 20' BI-PARTING IRON GATE (A51248)
UNUSED CHERY...
