TBN differences
   / TBN differences #1
Garrabo
Banned
GA
3120,X-575,BX1830,BX22
I was looking at a TBN chart for several different oils, Including the Mobil supersyn. I was wondering why the TBN rate was 5.0 and other oils are up around 9.0,12.0, even 14. Do diesel motors require a higher TBN? It all kinda confuses me.
   / TBN differences #2
the higher the TBN the better the oil. That is the quick and easy version. As you use the oil the TBN drops as an exponential function. It is not linear. So the more you use the oil the lower the TBN becomes.
And yes diesel need a higher # since there are very acidic. I would stay away from TBN lower then 9 but that is me.
   / TBN differences #3
Where did you see the TBN chart? I'd like to see it and find a good oil for my tractor. thanks, brett
   / TBN differences
I,ve heard that Delvac 1300 super is fine to use in gasoline motors.
The Delvac has a 12 on th TBN chart, But My 04 F-150 calls for a 5W20 so I went with the 0W20 mobil Super syn which has a TBN of
5. I've got a free oil test kit on the way so I'll see what is is or isnt doing. I tryed to post the TBN chart but I'ts to big.
   / TBN differences
seems like the amsoil is a little betterTYPICAL TECHNICAL PROPERTIES (Revised 4/03)
AMSOIL SAE 5W-20 XL-7500 SYNTHETIC MOTOR OIL
5W-20
(XLM)
Kinematic Viscosity @ 100°C, cSt (ASTM D-445)
8.9
Kinematic Viscosity @ 40°C, cSt (ASTM D-445)
45.0
Viscosity Index (ASTM D-2270)
183
CCS Viscosity, cP @ (°C) (ASTM D2602)
3670 (-30)
Flash Point °C (°F) (ASTM D 92)
229 (444)
Fire Point °C (°F) (ASTM D 92)
242 (468)
Pour Point °C (°F) (ASTM D 97) -46 (-51)
Noack Volatility, % weight loss (g/100g) (DIN 51581)
8.2
High Temperature/High Shear Viscosity @ 150°C and 1.0 X 106 s-1, cP (ASTM D4683)
2.9
Four Ball Wear Test (ASTM D 4172 @ 40 kgf, 150°C, 1800 rpm, 1 hour, Scar in mm)
0.38
Total Base Number (ASTM D2896) 10.2
   / TBN differences #6
Maybe try a PDF file for Brett?
   / TBN differences #7
I would also look at the ZDDP also.
If you are using normal to slightly longer drain intervals, then lower levels of ZDDP (zinc diaryldithiophosphate) really don't matter that much. If you run drain intervals less then 10,000 miles. The Amsoil, XL-7500 Series oils contain low levels of ZDDP comparable to Mobil 1, but they are only intended for 7500 mile drains.
Also levels of ZDDP prevent excessive oxidative thickening over extended drain intervals. But again if you are not using the full service life of the oil, why bother with a high ZDDP or a group 4 or 5.
So pay attention to Zinc/Moly, Phosphorus, Boron & Ca and TBN for a good oil. Some oil at price X are lower and some are higher.
   / TBN differences
I'll try this
Not to good, The chart looks alot better.
anyone that wants it please send $49.95 /forums/images/graemlins/grin.gif Kidding.
I can e-mail it easier .
   / TBN differences #9
I just downloaded it from the site.
   / TBN differences
I didnt notice that the URL was there /forums/images/graemlins/blush.gif
2" X 3" ANGLE IRON UP TO 16' LONG (A51247)
2" X 3" ANGLE IRON...
ATLAS XAS110 COMPRESSOR (A52472)
ATLAS XAS110...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A53426)
2018 INTERNATIONAL...
MIDEA 8000 BTU WINDOW AC UNIT (A51248)
MIDEA 8000 BTU...
FRONTIER AV50H LOT NUMBER 101 (A53084)
FRONTIER AV50H LOT...
2012 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Versalift SST40 Boom (A53472)
2012 RAM 5500...
