TB serial numbers
/ TB serial numbers #1
heehaw
Veteran Member
russellville, arkansas
Kubota M4900, B7510 and RTV
i have 4 troybilt tillers, in various states of disrepair: one i have borrowed, an its the only one that works: i just bought a new motor for one that the briggs motor threw a rod: so i bought the rest of the tiller, last year: am trying to figure out, about what year they are: heres the list, with what i think is the newest first:
Model 12087: sn 120870101600 this is the one i have the new motor for:
sn 643647 this has an electric start kohler: won't start
sn 512119 this one is borrowed: it has a pull start kohler, an works pretty well:
sn T306297 this one does not have a motor, an has the bearings out in the tine area:
does anyone have a list of sn's an year of manufacture?
heehaw
/ TB serial numbers #2
I tried those numbers at the MTD online manual site and came up with manuals only, no years.
If you have an original Briggs & Stratton engine check the code number, the first two numbers are the year, the second two numbers are the month the engine was made. My new to me Pony has a code of 9702.... so I know the engine was made in feb of 97, so I assume my Pony is a 97
Somewhere I saw a site that you can find a year by using the model and serial numbers. I will look and let you know if I find it.
/ TB serial numbers #3
SERIAL NO.
This will tell what years the Kohler engines were made
Letter code
A............1965
B............1966
C............1967
D............1968
E...(early)1969
First 2 digits if 7 digit number
10-19.(late)1969
20-29........1970
30-39........1971
40-49........1972
50-59........1973
60-69....... 1974
70-72........1975
73-79........1976
80-89........1977
90-94........1978
95-99........1979
First 3 digits if 8 digit number
100-109....1980
110-119....1981
120-129....1982
130-139....1983
140-149....1984
150-159....1985
First 2 digits if 10 digit number
15.....(late)1985
16............1986
17............1987
18............1988
19............1989
20............1990
21............1991
22............1992
23............1993
24............1994
25............1995
I assume it continues with the same pattern. My 2000 Kohler is 30
/ TB serial numbers #4
OK heehaw, I found the year of 2 of your tillers.
SN 643647.....1982
SN 512119.....1980
SN T306297... I don't know what the T means but if this is a horse that number is from 1978. Not at all sure about this until I find out what that "T" means.
My list only goes up to 1992
/ TB serial numbers
they are all the horse model: but the 643647 and the 0101600 both have the lever on the side that will disengage the tines: i am pretty sure only one has the original engine: an that the one with the T in front...the 0101600 was bought by a friend about 1999 or so?? it threw a rod in the BS motor, probably ran it with out oil, but it has had very little use...so i am going to stick the new HF motor on it..thanks for the info..
heehaw
2018 Ram 1500 Reefer Meal Delivery Truck (A61573)
2018 Ram 1500...
John Deere PT 15' Batwing Mower (A64911)
John Deere PT 15'...
CAT J600 Teeth (2) (A68134)
CAT J600 Teeth (2)...
2006 PETERBILT 379 (A67714)
2006 PETERBILT 379...
MQ Power MQP80IV Industrial Generator (A64912)
MQ Power MQP80IV...
2010 Ford Expedition LTD (A64911)
2010 Ford...
