taylor way disc repair
/ taylor way disc repair #1
C3ole
la
john deere 2440
I need to know how get the disc pans off. how to seperate the axle housing- dish pan spacers. thanks for any help you can give me.
/ taylor way disc repair #2
Don't know what model your's is or haven't seen it but most all I've repaired you just remove the large nut on the end of the axle and the individual disc and spacers just slide off one at a time.
You'll have to remove the hangers holding the section to the frame. This is a sure finger masher.:)
Make you a little diagram before removing each piece so it goes back together right.
/ taylor way disc repair #3
Take lots and lots of pictures with your phone. I did this and it helped tremendously when the time came to re-assemble the disk. Good Luch.
You will need to drop the entire disk gang assembly (axle, spacers, pans, bearings, hanger )
You will need to take the large nut off the end (may need to build a special wrench if you cant find one that fits. May need to use heat, will probably need to use a cheater bar. I actually purchased some specialty wrenches from my dealer (JD) that were about 6' long. You may want to try to get the axle nut loose before you drop the gang assembly.
I refurbished 2 disks so far. One had round axles and one had square axles. Start sliding the components off one at a time and keep up with what order they go back on. They should all be held together by the pressure of the tightened nut. When you put it all back together, you need to REALLY tighten this nut. Not sure you can get it too tight. Run the disk a while, and try to tigheten it some more.
2023 TEXLINE BOBCAT HAULER (A65643)
2023 TEXLINE...
DRILL CABINET SKID (A60736)
DRILL CABINET SKID...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
2000 Sterling L9511 Triaxle Dump Truck, VIN # 2FZNNWYB8YAB42893 (A65563)
2000 Sterling...
3 Point Hay Forks (A62613)
3 Point Hay Forks...
76in. Skeleton Skid Steer Grapple (A65640)
76in. Skeleton...
