Backhoe Taylor Way backhoes
/ Taylor Way backhoes #21
We were trying to find Disc for a Taylor-way Disc Harrow and when we called them .they said they had sold out and no longer made any thing.I think they when belly up.
/ Taylor Way backhoes #22
Taylor way is a brand of products from Taylor Pittsburg, Backhoes are made in Italy and are good in quality,Most hydraulis shops have metric fittings
/ Taylor Way backhoes #23
I'd like to hear more from you guys that have purchased the Taylor/Way Hoes. I have an older Kelly which is a great unit but 8Ft. unit an is a bit much for my JD 870 (28 H.P.) tractor. Just afraid to sell what I know is a great unit for something thats not and regret it later. Really concerned about available replacement parts for cylinders, pump ETC. Any help or comments from owers whould be greatly appreciated. Bernie
/ Taylor Way backhoes #24
I just bought a Model 766. Since I only have few hours on it, I can't really comment on overall quality. I can say that my initial impression is positive.
/ Taylor Way backhoes #25
I'm interested in your 8ft. hoe when you get a smaller one. I have a JD1050,I think it will be OK on.
/ Taylor Way backhoes #26
I think this is a really good reason to get a bigger tractor. Keep the hoe and upgrade the tractor.
Wedge
/ Taylor Way backhoes #27
Sorry for not replying any sooner but haven't been on this site in a while...been RV'ing, fishing and riding the Harley. I've used my Taylor Ways backhoe on several projects here at the house and have trailered the tractor to my nephew's house to dig footings for his retaining wall. The only concern I had was the "jerkiness" so I call Taylor Tech Dept to ask if there's a hydraulic control valve. I was told there wasn't one but to replace the Hydraulic fluid with 40 wt motor oil. Other than than, I'm quite pleased with this backhoe. I have yet fabricated a subframe, but plan to this spring.
BTW I called several places for a 12" bucket for the backhoe but was told that it had to be an aftermarket bucket. I did find an outfit that builds custom buckets so I ordered and have received a 12" wide bucket. But I have yet mounted it or used it.
/ Taylor Way backhoes #28
I'm very impressed with mine. It has done everything that I have asked. I did build the subframe because the 3pt setup is very week.
I only wish it was larger and had a longer reach.
Phil
/ Taylor Way backhoes #29
dfkrug said:
I have never seen a Taylor-Way, but I have heard good
things about them and, like my Prairie Dog 7.5,
they are very competitively priced. I don't know of any
dealer out west carrying them. The quotation of
$4300....is that for the 6.5' hoe or a bigger one?
Is the Prairie Dog from Grand Blanc Tractor Sales ? I just sent them an e-mail.
They are only 300 miles south of me so I can go pick it up.
Do you know if the $4195 price include a sub-frame? It suggests "3 point hitch attachment FREE with every backhoe purchase". Also, do you know how much the PTO pump is?
/ Taylor Way backhoes #30
It sure looks like 3pt only. You could make or adapt a subframe. I downloaded the brochure which states pto pump & tank $495.00 with backhoe purchase.
/ Taylor Way backhoes #31
Drove to Kentucky in a pickup truck and had a look at the 766, I bought it last winter, and put a good 40 hours on it last summer, almost got the smaller model (Taylor Way 700), sure am glad I bought this model.
What this can't do I'll live without, but any smaller and doubt I'd be happy. Way too many rocks and stumps here..Before I did any digging, made a subframe for it, feels solid and strong, pulled rocks weighing couple hundred pounds each with very little strain. My tractor with hoe weighs about 4000lbs, but if I don't add 500lbs of rock in the FEL it will toss the tractor a little.
Here's mine biting off more than it can chew.
/ Taylor Way backhoes #32
I am looking for a taylor way dealer in or around Utah. Any ideas?
/ Taylor Way backhoes #33
Welcome to TBN slickrock;:)
Can't help you on your TW dealer question, but can tell you the TW hoe is very heavy duty and with minor issues has been GREAT for me.
Hope you find what you want, and good luck....
ps: I did find a place a lot closer that sold them but the salesman lied to me about cost on the phone, I called again right before I was to drive up and look (170miles) and the story changed ...a lot! I most likely woulda bought it from them if I hadn't been lied to.
/ Taylor Way backhoes #34
irwin or philbuilt, did you guys ever post photos of your subframe?? (or can you, please :)). Thanks... Interested in how you attached the backhoe to the subframe.
/ Taylor Way backhoes #35
Hi teg;
Really Phil's subframe is much better looking than mine, check out his pond building thread toward the end he has a picture of his.
Here's what I threw together.
I then tacked them together, removed it, cut off excess, and welded it up then strenghtened it with gussetts.
Then I welded the piece for the TW top link on an angle like the Deere subframe is for the model 7 backhoe...Excuse the dirt and rust, don't have any better pic's.
/ Taylor Way backhoes #36
irwin, Thanks!! That's what I was needing to see and also what I need to build...:rolleyes: gotta'nother request? Do you have a photo of these two welds :eek: (see attach) ...and, I'll look up Phil's... but I think I had seen it (and studied it) a dozen times already ;).
/ Taylor Way backhoes #37
Teg,
Here is the link to my sub frame.
http://www.tractorbynet.com/forums/customization/95563-woods-1012-fel-mount-problem-2.html
The frame is Strong and did not take away any ground Clarence.
I may have a few more pic's on the pond link.
This top picture is the frame that I welded to the BH and that is how it
is connected in the front under the platform. just slides in.
You can see here how the frame is pinned. The draw bar would have been
enough. Better safe than sorry.
This little BH will pick up the back of the tractor on point and rotate and set it back down over left or right. I'm very impressed.
I hope that this helped.
Phil
/ Taylor Way backhoes #38
Sorry teg: I don't have any better pictures now, but if you look at the picture you attached, and at these, the cross piece is 3/8 channel with 3/8 plate welded on back to box it in. The welds were finished after it all was tacked together later.
/ Taylor Way backhoes #39
First off, thanks to you both for posting... Tim, I understand yours and lean towards that one... (I'll reply to Phil's work of art :) below). My subframe will look more like yours, two arms coming out the back with a triangle hookup for the top link (not sure if I'll use the tractors top link for extra support or not). I assume you use the backhoe to align the holes for the six bolts... then bolt it together. You don't have any other hooks or notches to help align the holes?
I have the subframe worked out (at least in my head :eek:). I need more wisdom of how to mate the two together, and instead of "stealing" this thread, I should start a new one. :eek:
Phil, I loved how you used the draw bar... I might work that in. It's a great piece of work, and something to be proud of. I'm not worried about ground clearence (or looks, for that matter). I live by Keeping It Simple, the subframe I have in mind, will be easier to build... then to connect or remove. Thanks guys... Teg/Dan
/ Taylor Way backhoes #40
i just bought a taylor 766 used three point hitch backhoe and i put it on a l 2850 kubota and it works like a charm i wouild buy one
Oxy-acetylene Torch and Regulator Rig (A63689)
Oxy-acetylene...
2007 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A58375)
2007 FORD F750 XLT...
Cat CB24B (A60462)
Cat CB24B (A60462)
UNUSED WOLVERINE 3PT QUICK HITCH (A64281)
UNUSED WOLVERINE...
2016 MACK CXU613 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2016 MACK CXU613...
2022 Case CX220E Hydraulic Excavator (A61572)
2022 Case CX220E...
