Tattle tale plug leaking
/ Tattle tale plug leaking #1
Bill_X
Kubota L2250
I have a 1988 Kubota L2250F (2 wheel drive, 1100 hrs). Recently I noticed a little bit of transmission/hydraulic oil dripping from what, I found out today, is called the tattle tale plug. I am curious if anyone has had experience. The service guy at the Kubota dealership closest to me said it meant something was wrong inside the transmission case but gave no more advice than that. Any help would be appreciated. Thanks.
/ Tattle tale plug leaking #2
Can you tell if it's hyd oil or motor oil?
/ Tattle tale plug leaking #3
Engine rear main seal or transmission seal is leaking. Fixing either requires splitting the tractor. If it's black it's engine, somewhat clearish it's tranny.
You can ignore it & hope it doesn't get to bad or contaminate the clutch or split & replace the seal. It could be worn bearings leading worn seals, or just worn seals.
2018 BOBCAT E50 EXCAVATOR (A64279)
2018 BOBCAT E50...
2018 CATERPILLAR D6T XL HIGH TRACK CRAWLER DOZER (A62129)
2018 CATERPILLAR...
JMR Tree Boom Skid Steer Attachment (A61572)
JMR Tree Boom Skid...
9 SHANK CHISEL PLOW (A63291)
9 SHANK CHISEL...
2019 Ford Explorer AWD SUV (A61574)
2019 Ford Explorer...
2005 LEDWELL LW40ADC - 40' ALUMINUM FEED TRAILER (A63290)
2005 LEDWELL...
