Tata Motors Diesel mini truck
   / Tata Motors Diesel mini truck #1
odleefs
Northeastern PA
2005 Bobcat/Toolcat 5600T C, 2000 Yamaha Grizzly
Here is a link to the Tata Ace. It is a 700 cc diesel mini truck. The price is probably competitive with used Japanese mini trucks, as Tata is extremely price competitive!
Info below was taken from the following site:
http://ace.tatamotors.com/specifications.html
ENGINE
Model : TATA 275 IDI NA BS-II (and BS-III)
Type : 4-stroke, naturally aspirated, indirect injection diesel engine
Max. Output : 16 hp @ 3200 rpm
Max. Torque : 3.8 mkg @ 2000 rpm
Displacement : 700 cc
Special Items : catalytic converter (only in BS III)
CLUTCH : Single plate dry friction diaphragm type
GEAR BOX : GBS 65-4/5.27
Type : Synchromesh (4 forward gears), Sliding mesh (reverse gear)
STEERING : Mechanical, variable ratio (20.5 to 24.5), 380 mm dia
BRAKES
Type : Dual circuit hydraulically activated
Front : Disc brakes
Rear : Drum brakes (200 mm dia x 30 mm)
Parking Brake : Cable operated mechanical linkages acting on rear wheels
SUSPENSION
Type : Parabolic leaf spring suspension at both front and rear
Shock absorber : Hydraulic double-acting telescopic type both at front and rear
WHEELS AND TYRES
Tyres 145R12 LT 8PR RADIAL
FUEL TANK Capacity 30 liters
PERFORMANCE
Max. Speed : 64 kmph (40 mph)
Max. Gradeability : 16%
Grade restartability : 15%
LOAD BODY
Type : Pickup type. Hinged rear tail gate
Loading height : 675 mm
Load Body (external) : Length 2200 mm
: Width 1500 mm
: Height 300 mm
DIMENSIONS All in mm
Overall Length (A) : 3800
Width : 1500
Wheel base (D) : 2100
Overall height ゥ : 1820
Track Front (E) : 1300
Track Rear (F) : 1320
Min Turning Circle Dia : 8.6 m
WEIGHTS
Max. GVW : 1550 kg
Kerb weight : 805 kg
Seating capacity : Driver + 1
Here are the specs on a wildfire250T three wheeled utility truck. Info taken from wildfire hp.
Fuel Efficiency 72 Miles Per Gallon
102L x 51W x 64.5H
Engine 248cc Hi-Po Liquid Cooled
Rated HP 17
Ignition CDI
Transmission 5-Speed Manual, Plus Reverse
Max Speed Up to 50 mph
Cruising Speed 40 mph
Net Weight 790 lbs
Gross Weight 1290 lbs
Brake Disk/Drum
Tire Size 4.00-12 Front 4.50-12 Rear
Battery Heavy Duty, Full Size U1L
Load Capacity 550 lbs
Accessories Front Heater
Tire Jack and Spare Tire with Cover
Collapsible bed sides
Sunroof
2 Door
AM / FM Radio with Cassette Player
2013 Kia Soul Hatchback (A51694)
2013 Kia Soul...
2020 PETERBILT 567 DAY CAB (A53426)
2020 PETERBILT 567...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
Gravely Compact Pro Zero Turn Mower (A53117)
Gravely Compact...
Toro Workman Low Profile Spray system 200 (A50322)
Toro Workman Low...
2021 M&J PRESHRED 4000M SHREDDER (A53426)
2021 M&J PRESHRED...
