Tata Motors Diesel mini truck
   / Tata Motors Diesel mini truck #1
odleefs
Northeastern PA
2005 Bobcat/Toolcat 5600T C, 2000 Yamaha Grizzly
Here is a link to the Tata Ace. It is a 700 cc diesel mini truck. The price is probably competitive with used Japanese mini trucks, as Tata is extremely price competitive!
Info below was taken from the following site:
http://ace.tatamotors.com/specifications.html
ENGINE
Model : TATA 275 IDI NA BS-II (and BS-III)
Type : 4-stroke, naturally aspirated, indirect injection diesel engine
Max. Output : 16 hp @ 3200 rpm
Max. Torque : 3.8 mkg @ 2000 rpm
Displacement : 700 cc
Special Items : catalytic converter (only in BS III)
CLUTCH : Single plate dry friction diaphragm type
GEAR BOX : GBS 65-4/5.27
Type : Synchromesh (4 forward gears), Sliding mesh (reverse gear)
STEERING : Mechanical, variable ratio (20.5 to 24.5), 380 mm dia
BRAKES
Type : Dual circuit hydraulically activated
Front : Disc brakes
Rear : Drum brakes (200 mm dia x 30 mm)
Parking Brake : Cable operated mechanical linkages acting on rear wheels
SUSPENSION
Type : Parabolic leaf spring suspension at both front and rear
Shock absorber : Hydraulic double-acting telescopic type both at front and rear
WHEELS AND TYRES
Tyres 145R12 LT 8PR RADIAL
FUEL TANK Capacity 30 liters
PERFORMANCE
Max. Speed : 64 kmph (40 mph)
Max. Gradeability : 16%
Grade restartability : 15%
LOAD BODY
Type : Pickup type. Hinged rear tail gate
Loading height : 675 mm
Load Body (external) : Length 2200 mm
: Width 1500 mm
: Height 300 mm
DIMENSIONS All in mm
Overall Length (A) : 3800
Width : 1500
Wheel base (D) : 2100
Overall height ゥ : 1820
Track Front (E) : 1300
Track Rear (F) : 1320
Min Turning Circle Dia : 8.6 m
WEIGHTS
Max. GVW : 1550 kg
Kerb weight : 805 kg
Seating capacity : Driver + 1
Here are the specs on a wildfire250T three wheeled utility truck. Info taken from wildfire hp.
Fuel Efficiency 72 Miles Per Gallon
102L x 51W x 64.5H
Engine 248cc Hi-Po Liquid Cooled
Rated HP 17
Ignition CDI
Transmission 5-Speed Manual, Plus Reverse
Max Speed Up to 50 mph
Cruising Speed 40 mph
Net Weight 790 lbs
Gross Weight 1290 lbs
Brake Disk/Drum
Tire Size 4.00-12 Front 4.50-12 Rear
Battery Heavy Duty, Full Size U1L
Load Capacity 550 lbs
Accessories Front Heater
Tire Jack and Spare Tire with Cover
Collapsible bed sides
Sunroof
2 Door
AM / FM Radio with Cassette Player
2024 JOHN DEERE CP 770 LOT IDENTIFIER 22 (A53084)
2024 JOHN DEERE CP...
Kubota Salt-Spreader (A52384)
Kubota...
2019 Fontaine EQ1 Hydraulic Equalizing Spreader (A52377)
2019 Fontaine EQ1...
2012 Club Car Carryall 1 Utility Cart (A51691)
2012 Club Car...
(1) 330 GALLON POLY TOTE W/ CAGE (A51248)
(1) 330 GALLON...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
