tanny fluid level too hight?
   / tanny fluid level too hight? #1
Rusty4242
Western Mass.
Kubota BX23
I just checked the fluid level with the dipstick of my BX23 and found the level to be about an inch above the hight mark. Could this cause problems as it wood with a cars automatic tranny? It has 120 hours on it, and the oil is clean. Thanks, Larry
   / tanny fluid level too hight? #2
I would let a little out to get it closer to the correct level, I don't think it will hurt anything but when my fluid was high on my BX23 it would leak out of the vent
   / tanny fluid level too hight? #3
Don't know how similar the BX is to the B7610 but I get really low levels most of the time when I first pull the stick because the O ring seals the tube at the top. If I pull the stick out, give the oil a minute to equalize then put the stick back in and the oil will be just right.:cool: Worth a try before you start trying to drain 'some' oil out of the case.
2007 TEREX ADVANCE FD3000 FRONT DISCHARGE AWD MIXER (A59575)
2007 TEREX ADVANCE...
2018 Ford F-150 Pickup Truck (A56858)
2018 Ford F-150...
large capacity skid steer bucket (A56857)
large capacity...
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
Unused SDLWC Wood Chipper (A55272)
Unused SDLWC Wood...
2003 International 7400 T/A Heil 12 CuYd Dump Truck (A55853)
2003 International...
