Tank size for a log splitter?
   / Tank size for a log splitter? #1
Tenn_Blue
N.E Tennessee
Deere 2320, Bobcat 322 mini-ex, Bobcat 763 skidsteer
I have a home made 3 point log splitter that used to belong to my brother in law. BIG, heavy and made out of an i beam. Also, probobly too much flow required for use with my little Deere 2320 tractor.
I have a 6.5 horse gas motor sitting around, and want to convert the splitter to a self contained, trailer mounted unit. Have been looking at gas powered splitter specs, and here is what I have so far;
This looks to be a 4" cylinder with about 18 inches of travel. As I said, have a 6.5 hp motor to go on it. Plan to get a 11gpm 2 stage pump.
How big of a hydraulic tank should I have for this setup? I have seen some splitters advertised with a 1.5 gallon tank?!?! I would thing you would want more than that for cooling.... I have a 7 gallon hydraulic tank, but would that be overkill for this setup?
Thanks for the help...
   / Tank size for a log splitter? #2
Your 7 gal tank would work quite well.
Some say 1 gal of fluid for each gal of pump flow
   / Tank size for a log splitter? #3
7 gal would be good, you can't go too big but you can go too small.
I've got a 13hp driving an 11gpm pump with a 8 gal tank. It starts to get warm after a couple hours running. Rememebr if you do build your own to make sure to have the return at one end and the suction at the other
....Mike
2005 Frieghtliner 18' Box Truck (A52377)
2005 Frieghtliner...
2011 Case 3020 30ft Flex Draper Head WITH TRAILER (A53473)
2011 Case 3020...
2004 JOHN DEERE  310SG BACKHOE (A53843)
2004 JOHN DEERE...
2014 Ford Fusion SE Sedan (A53424)
2014 Ford Fusion...
Adams 5 T Spreader (A53473)
Adams 5 T Spreader...
JOHN DEERE 1725 CCS (A53084)
JOHN DEERE 1725...
