Tank aireator ideas?
/ Tank aireator ideas? #1
Dachshund
Nebraska, USA
Ford 8N, International 454, Farmall M
I use a couple of old bath tubs for stock tanks. I have been having trouble with algae growth in them. Aireation SHOULD help the problem. I'm trying to figure out how to convert wind power into an air "puffer". I have a couple of ideas, but just wondered if anyone else has any. Thanks!
/ Tank aireator ideas? #2
I don't have the link anymore, but 6 or 7 years ago a friend researched a windmill air pump to keep a duck pond clear of ice during the winter. Bigger system then you are looking for but had some good concepts. Sorry I'm not more help, but the product is out there.
/ Tank aireator ideas? #3
I saw an old windmill that had the sucker rod hooked up to a trucks air lift bag. He had a check valve added to the air bladder and it was doing a good job of aerating his pond without the help of electricity.
/ Tank aireator ideas? #4
We always used to put a piece of copper in the tank to control algae.
/ Tank aireator ideas? #5
Couple the windmill to an air pump of your choice. Run line to your tanks. In the bottom of the tank have a short piece of pipe with several small holes. Something like a rotary vane pump, or air compressor pump. I don't know how much "power" it would take to run an air compressor pump. It would have to run very fast to generate enough air.
/ Tank aireator ideas? #6
What about have the windmill arm hooked to something like a bellow blower.
Other option is to add a couple goldfish.
I have a couple stock tanks in the 120g size and keep a couple goldfish in each... No bad algea problems in 6 years (yet).. and no mosquito larve...
Soundguy
/ Tank aireator ideas? #7
Check out the website www.pondboss.com the go to the section where its says ask the boss, it is the forums and like here there are a great bunch of guys that seem to know what they are talking about and are really willing to help.
Thanks for the info Guys! I gotta rig something up in the next few weeks.
/ Tank aireator ideas? #9
They come ready made for koi ponds. Try http://www.pondaeration.com/
Air may help keep the water in better condition but I don't think it will clear algae. It will affect water condtions and affect the algae but if it's just algae you are worried about I doubt it will work to remove it.
I have a little compressor in the garage that uses about 45 watts and I run air tubing a couple hundred feet to a pond 24/7.
Zeuspaul
/ Tank aireator ideas? #10
For an air pump, you can use an old 4 stroke engine. Have the windwill turn the drive shaft and connect your aerator to the exhaust.
/ Tank aireator ideas? #11
My 5000 gal drinking water tank is aerated 24/7 by a 120V
aquarium bubbler and a 3.5" chassis fan. My well water has
dissolved hydrogen sulfide gas. This system works great for
my application. I run 500 ft of #10 solid copper to the tank.
The fan is only necessary due the the closed top on the tank.
I did not know that aerating water would kill algae.
2017 International 4300 Box Truck (A62613)
2017 International...
2001 THOMAS-INTERNATIONAL 3800 SCHOOL BUS (A62130)
2001...
PALLET OF RIMS, TOOLBOXES & MISC (A63745)
PALLET OF RIMS...
2020 DRAGON ESP 150BBL ALUMINUM (A63569)
2020 DRAGON ESP...
2009 Mariah SC23 23ft. Cabin Cruiser with T/A Boat Trailer (A61569)
2009 Mariah SC23...
43024 (A59228)
43024 (A59228)
