tank 48 breaking belts suddenly help me
   / tank 48 breaking belts suddenly help me #1
nworbekim
southern Kentucky, USA
mahindra 3510
2 years and i've not broken a belt, now all of a sudden i've broken 2 in 2 weeks! its the top belt, from the motor to the top of the deck, it turns the deck...
is there an underlying reason? maybe a pulley or rotor blown?
   / tank 48 breaking belts suddenly help me #2
Do all the pulleys that belt touches spin nice, with no wobble and they're all lined up the way they should be?
Joel
   / tank 48 breaking belts suddenly help me #3
might also want to make sure you've installed sn OEM belt vs. an aftermarket belt. They are more $$, but are usually made with kevlar & will hold up. Also make sure that loaded idler pulley isn't touching the belt backs together - my SIL had a 2560 tank that the pulley clearance was real tight - hadta adjust the deck forward.
   / tank 48 breaking belts suddenly help me #4
Often it is a idler issue! bad bearing or they are bent causing the belt to come off.
LMC LOT NUMBER 269 (A53084)
LMC LOT NUMBER 269...
Towable Orchard Sprayer (A51691)
Towable Orchard...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
New/Unused Mower King 48in Quick Attach Trencher (A51573)
New/Unused Mower...
CATALOG UPDATES (A53084)
CATALOG UPDATES...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
