tank 48 breaking belts suddenly help me
   / tank 48 breaking belts suddenly help me #1
nworbekim
Bronze Member
southern Kentucky, USA
mahindra 3510
2 years and i've not broken a belt, now all of a sudden i've broken 2 in 2 weeks! its the top belt, from the motor to the top of the deck, it turns the deck...
is there an underlying reason? maybe a pulley or rotor blown?
   / tank 48 breaking belts suddenly help me #2
Do all the pulleys that belt touches spin nice, with no wobble and they're all lined up the way they should be?
Joel
   / tank 48 breaking belts suddenly help me #3
might also want to make sure you've installed sn OEM belt vs. an aftermarket belt. They are more $$, but are usually made with kevlar & will hold up. Also make sure that loaded idler pulley isn't touching the belt backs together - my SIL had a 2560 tank that the pulley clearance was real tight - hadta adjust the deck forward.
   / tank 48 breaking belts suddenly help me #4
Often it is a idler issue! bad bearing or they are bent causing the belt to come off.
HLA LOT NUMBER 168 (A53084)
HLA LOT NUMBER 168...
FAE UML/SSL 150 VT BL HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
2006 KOMATSU  D41P-6  CRAWLER TRACTOR (A52576)
2006 KOMATSU...
48 PIECE HEAVYEQUIPMENT KEY SETS (A52472)
48 PIECE...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2015 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
