Tandem vs Open Center for a Grapple
   / Tandem vs Open Center for a Grapple #1
irsmun
Bronze Member
East TX
2024 Mahindra 5145 4WD
It has been about 12 years since I first installed my 3rd function. I have a new tractor so I have to do it again. There is something I cannot remember about the valve. I have an open system. For a grapple, do I need a tandem center valve or open center. If my memory serves me, and it usually doesn't, a tandem center will allow the work ports to stay shut thus keeping the grappled closed with tension. With an open center valve, pressure will release when I go to neutral (not push the button)? Am I correct?
   / Tandem vs Open Center for a Grapple #2
Yes, you need a tandem center valve if it is a D03 or D05 subplate mounted valve.
   / Tandem vs Open Center for a Grapple #3
Yes, a tandem center valve has the work ports blocked in neutral, a true open center valve has them open to the tank-good for running motors.
But, many sources will use the term open center in place of tandem center.
2020 Global R3 Air Street Sweeper (A56857)
2020 Global R3 Air...
Amada M-3060 Mechanical Metal Shear (Japan) (A59213)
Amada M-3060...
LayMor Sweepmaster 300 8HC (A55314)
LayMor Sweepmaster...
Forklift (A59228)
Forklift (A59228)
2018 Honda TRX250TM ATV (A56859)
2018 Honda...
Case-IH 165 Puma (A57148)
Case-IH 165 Puma...
