Tanaka ecs-3351 d - Chain??
   / Tanaka ecs-3351 d - Chain?? #1
niall.of
none
Hi all,
Re above, does anyone know what size chain I need? Google says the chain bar is 14"
Looking at Tanaka website, I see 14 x 3/8
   / Tanaka ecs-3351 d - Chain?? #2
The numbers should be stamped on the bar. You need the pitch (i.e. 3/8 or .375 or 3/8 Low Profile), the gauge (i.e .50, .58) and the number of links. With those three numbers you can order chain from anyone even if they have no clue what a Tanaka needs.
A 14" bar probably does not use regular 3/8 but would be likely to have 3/8 LP. It's smaller than normal 3/8 with a narrower kerf.
Bailey's has a massive chainsaw chain selector on their web site that lets you find chains by the saw and bar length.
   / Tanaka ecs-3351 d - Chain?? #4
As Ericm979 mentioned, Baileys has a Chainsaw Bar Selector on their web site. Go there, choose your brand and model of saw from the column on the left, and they will present you with a number of choices. Since some saws have a variety of optional bar lengths, you'll need to have an idea of what length you want.
They have a similar selector for chains (assuming you have already selected your bar length).
UNUSED Red Corrugated Polycarbonate Roof Panel (A53117)
UNUSED Red...
Pallet of UV Solid Hardwood Flooring (A55758)
Pallet of UV Solid...
2023 UNVERFERTH 432 (A53084)
2023 UNVERFERTH...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
2016 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2016 Ford F-550...
UNUSED FUTURE FT90 PLATE COMPACTOR (A52706)
UNUSED FUTURE FT90...
