Talk Me In/Out of the Stihl MS261
   / Talk Me In/Out of the Stihl MS261 #171
@Hay Dude , dealer sent me info on another option from Danuser, which is a little shorter and also opens full vertical, so as to not interfere with pallet handling. But the Danuser unit has the hinge set real low, like 18” above forms, so probably not as good for grabbing big stuff.
Of course, my loader weight capacity also doesn’t allow me to pick up huge logs, but I do often handle big (40” diameter) shorties, which I think the HLA would grab better.
HLA is a little tall to fit thru a door with arm up, but I could probably make it removable. What’s the overall height if yours with arm fully up?
HLA:
Danuser:
   / Talk Me In/Out of the Stihl MS261 #172
HLA:
Danuser:
I’ll have to measure for ya. It’s not really high.
   / Talk Me In/Out of the Stihl MS261 #173
No worries. I spoke with someone at HLA who said "about 79 inches", but I'm not sure from/to where he was measuring. My thinking is overhead doors are only 80 - 84 inches, and a lot of the box trucks I might be loading are not much taller than that. By the time you lose a few inches to the height of the skid itself, it could be tight getting pallets thru doors with that arm up.
But I think the low hinge and low height capacity of the Danuser when closed is a deal killer. If I have to cut the arm off the HLA and weld a hitch receiver type socket into which I can install/remove the thing, that's still better, to get the high hinge pivot capacity of the HLA.
   / Talk Me In/Out of the Stihl MS261 #174
The HLA is rugged as a bulldog
2017 Ford Expedition Limited SUV (A56859)
2017 Ford...
2012 NISSAN 110 FORKLIFT (A55745)
2012 NISSAN 110...
Sellick S60 Forklift (A57148)
Sellick S60...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
1999 FREIGHTLINER FL80 SWABBING UNIT TRUCK (A58214)
1999 FREIGHTLINER...
2023 54in. Hooklift Dumpster 15 Cubic Yard (A56858)
2023 54in...
