Richard
Super Member
- Joined
- Apr 6, 2000
- Messages
- 5,054
- Location
- Knoxville, TN
- Tractor
- International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
I'm at work right now and it's slow..... so I'm just meandering this in my head thinking aloud as I type. There is no significant meaning to this post other than conversation. :thumbsup:
My wifes cousin who lives next door, wants to work on his driveway and that means two dead trees need to come down (he cut them down) and unfortunately, a live hickory tree needed to come down.
He also wanted to dig out the rootball so he can put this back into a nice yard and not have to worry about the hole as the roots rot out.
On looking at the hickory, I sort of muttered out loud... "I wonder if instead of cutting it, we could simply dig on one side of it and push it over?" (I own an industrial backhoe/loader)
He left to go do something, was going to return in 10 minutes or so.
A bit curious... I started to dig rather gently. I had never done this before but reasoned that as long as I only dug on ONE side of the stump (near side) the tree should not fall towards me.
Not really trusting that to be foolproof.... I looked at the lean of the tree and fortunately, it was leaning in the same direction I was hoping it would fall (and that I intended to push)
As I was digging I caught myself digging more on what was the right side of the trunk and not quite as much on the left side. Not knowing how the roots were growing, I told myself that if I did not dig evenly, the tree MIGHT have a root on one side that holds tighter and allows the tree to twist in a direction I dont' want it to go.
So, I made sure that I dug on both sides as evenly as I could. I then put the bucket on the tree, (backhoe bucket about 10' UP the tree trunk) and gave a gentle push with the hoe. The tree fought back so I didn't force things.
I dug some more, maybe 1/4 to 1/2 bucketfulls of dirt since I couldn't really get a great bite in the dirt AND I was close enough to the tree so the hoe would be able to engage the tree about 10' up and still have some extension in the arm to push.
After digging a little more, I put the bucket back up to the tree and pushed. The tree bent. Actually, the tree leaned a bit since I noticed the roots moving. I kept that position and applied a little more pressure very slowly. The tree moved a little more and the rootball moved.
It dawned on me that this was in fact going to work and evidently, work fairly easily.
I pushed more but, rather than simply try to blunt push the tree over, I instead kept steady firm pressure on it and added more pressure. I wanted the tree to arc over pretty slowly so it would not, could not "spring back" towards me. I also knew that once I found some magic point in space, the weight of the tree would start to add to my pushing force.
The tree arc'ed over a little more and I kept the pressure on it. Half the reason for this pressure was to help force it over and the other half was to help prevent it from springing back in my direction.
The tree moved over more and started to fall on its own.
It was amazing to me how "gentle" this tree fell over. I've never really been part of a tree falling where there wasn't much of a WHUMP when it hit the ground. This tree, being alive was full of leaves. The canopy brushed into some other trees that I was trying to fall between and it was the brushing of these leaves/branches with each other that helped lay this tree down.
The tree fell exactly where I wanted it to fall.
After it hit the ground, my wifes cousin showed up and mouth was dropped open. He had basically driven to my father in laws house (2 doors down) picked up some tools and returned to this location which is next door.
This whole process probably took under 10 minutes and the root ball was up.
I ended up digging up the root balls of the other tree next to this one and it probably took me near 30 minutes to dig it up.
I don't know if this is considered a lot more safe or a lot more dangerous than dropping a tree with a chainsaw. I personally feel that I had more control of the situation and feel like I was more safe.
Today, now that I can see how easy it was to drop this tree and how well it worked, I wish I had borrowed my brother in laws video camera. It might have been an interesting YouTube video for others to see what I did. (there might already be videos out there showing this, I have no idea)
So, here I am at work right now....kind of slow....this is on my mind and I thought I'd share what I did.
Unfortuately this went SO easy and SO fast, it was over before anyone even thought about getting a camera so there are no pictures nor video of it.
