Tx Jim
New Member
RedNeckRacin
What I envisioned when Rick stated u-shaped shims was actually C-shaped shims. Just get a feeler type gauge and insert between drawbar & bracket to measure shim thickness required. Get 1/2 that thickness of metal the same width as drawbar is thick. Make shims 3 inches longer than drawbar bracket slot. Bend shim at 90 degrees one inch from each end,slide shims in turning 90 degree on each shim pointing towards each side(rear tires) then slide drawbar in between the shims. The 90 degree bends will keep the shims in place. My explanation is clear as mud isn't it!!!!!!
