Taking logs to the mill
   / Taking logs to the mill #1
Billrog
Veteran Member
Armstrong, British Columbia
Kioti 2610, 580 SuperM Case Backhoe
   / Taking logs to the mill #2
Nice...very nice. (y)
Cedar 30" at the butt. Never measured the length but it was a tall tree. Got enough lumber out of it to fill an order of 6x6,2x6, 4x4's & 1x6.
   / Taking logs to the mill #5
Nice. Hard to see the species from the photo. Now I see you’re from BC.
   / Taking logs to the mill #6
Nice cedar. Not only does it have some size, but you somehow grow it straight up there!
   / Taking logs to the mill #7
😲 Lucky to find 16-18 butts around here. Any that you do find usually has barbed wire buried in it. I would much prefer to build my outdoor stuff with cedar instead of this “new” pressure treated stuff.
I unhook the trailer and load with the tractor. I had a regular set of forks yrs. ago but soon found that's a good way to take front seals and bearings out on small tractors by over loading. So I made of 16" detachable forks. You can see in the pick I'm carrying a log in front of my bucket as well.
   / Taking logs to the mill #10
Yes I see what you mean - for the same reason I ended up dragging whole bunch of logs behind my tractor last fall by using a short logging chain.
These logs were not nearly as big as in your photo, but some were very long & heavy nevertheless.
Hybrid Poplars, loaded with water:
It was an experiment, but I will never again plant these species!
2004 Chevrolet C5500 Shuttle Bus (A50323)
2004 Chevrolet...
New Kivel Single Skidloader Spear (A50774)
New Kivel Single...
2021 John Deere 333G Two-Speed Hi Flow Compact Track Loader Skid Steer (A50322)
2021 John Deere...
2014 Doosan DA30 (A51039)
2014 Doosan DA30...
Ih 4300 Field Cultivator (A50514)
Ih 4300 Field...
2014 JOHN DEERE GENERATOR SET (A51222)
2014 JOHN DEERE...
