Taking apart 5600 to fix 50-56 error code
   / Taking apart 5600 to fix 50-56 error code #11
Wow, a few gremlins setting up residence in your toolcat.....good luck!
   / Taking apart 5600 to fix 50-56 error code #12
Thanks Jabonee. I couldn稚 reach behind it to get to the tabs. It痴 out now so I値l check those wires and let you know. The fuses are good, but I have had trouble with the relays.
On the steering wheel it turns out I need a puller to get it off the spline.
You may not need a puller. Try installing the nut back on loosely.Leave some room for the steering to move upward. Pull upwards on the steering while giving a SHARP BLOW to the nut with a soft hammer.That may pop it loose.
2016 Chevrolet Tahoe SUV (A56859)
2016 Chevrolet...
2021 WANCO, INC LIGHT PLANT (A58216)
2021 WANCO, INC...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
Zero Turn Mower (A59231)
Zero Turn Mower...
2014 VOLVO VNL (A55745)
2014 VOLVO VNL...
1994 Oldsmobile Cutlass Supreme (A57148)
1994 Oldsmobile...
