Taking a poll about crawl space vapor barriers
   / Taking a poll about crawl space vapor barriers #12
Your knees will thank you if you use sand, gravel is a killer. My preference would be the vapor barrier laid down, then followed by a thin layer of concrete, even just 2" would make for so much nicer and easier access over the years.
   / Taking a poll about crawl space vapor barriers #14
I am digging the footers for my addition today. After I get done digging them and regrading I would like to put plastic and gravel down as a vapor barrier.
My question is:
Plastic and then 57s gravel over it?
or
Gravel then plastic over it?
What says ye? Does anyone have personal experience with this? We're experiencing a lot of vapor smells coming from the dirt floor of our crawl space up through the back of the house crawl space vapor barrier. Regularly we get strong smells of sulfur (rotten eggs) and mold. The worst smell of wet concrete has been happening the past 2 weeks crawl space vapor barrier
Does anyone have personal experience with this? We're experiencing a lot of vapor smells coming from the dirt floor of our crawl space up through the back of the house. Regularly we get strong smells of sulfur (rotten eggs) and mold. The worst smell of wet concrete has been happening the past 2 weeks. I called a company that specializes in the installation of a vapor barrier that seals the dirt floor of the crawl space under a fabric/plastic lining. They also install a sump pump to keep the fumes directed out and away from the house. I don't mind saying that I just about fainted when they gave me a ball park figure of 3 to 5 thousand as an estimate to install this liner. Has anyone installed these and if so, what are your recommendations for this project? Is there a cheaper alternative that would be as effective as the more expensive contract for placement of this type of liner? Or should we just suck it up and go with the professionals?
   / Taking a poll about crawl space vapor barriers #15
Without specific details, hard to answer your question. The first question I'd ask is if water runoff slopes towards your crawl space. How big is your crawl space? Does it appear wet? Do you notice the odor all the time or at certain times?
My first suspicion of that kind of odor would be a blocked sewer vent that's allowing odors to back into your house or even a cracked sewer pipe.
   / Taking a poll about crawl space vapor barriers #16
Yes. Had a professionally done crawlspace. Difference is greater than night & day. I could have lived in the crawlspace. It's that clean & dry.
   / Taking a poll about crawl space vapor barriers #17
A few more feet and you could have had a basement. You would have loved the added living space.
   / Taking a poll about crawl space vapor barriers #18
Not a single house in that neighborhood with a basement. I knew the owner of the closest house to mine (about a mile away) with a basement. He said his sump pump ran 24/7/365 and his electric bill was sky high because of it.
If course my lawn was always green so there was that 😆
   / Taking a poll about crawl space vapor barriers #19
Another good thing is your well must not be very deep.
   / Taking a poll about crawl space vapor barriers #20
My grandson checked with a pest control company the other day about spraying for termites and they offered to put plastic under his house for 800 dollars and it's only about 1700 square feet.
2015 Ford F-250 Ext. Cab Knapheide Service Truck (A50323)
2015 Ford F-250...
1998 Kenworth Tandem Grain Truck (A50514)
1998 Kenworth...
IH Farmall 504 Tractor (A50514)
IH Farmall 504...
Oil Well Pump Jack with Motor (A49461)
Oil Well Pump Jack...
2014 Dodge 5500 4X4 Bucket Truck (A51039)
2014 Dodge 5500...
2001 KENWORTH T800 TRI AXLE TANKER TRUCK (A51222)
2001 KENWORTH T800...
