Taking a poll about crawl space vapor barriers
   / Taking a poll about crawl space vapor barriers #1
HawkinsHollow
SE TN
Branson 3015R
I am digging the footers for my addition today. After I get done digging them and regrading I would like to put plastic and gravel down as a vapor barrier.
My question is:
Plastic and then 57s gravel over it?
or
Gravel then plastic over it?
What says ye?
   / Taking a poll about crawl space vapor barriers #2
I say gravel is a bad idea. It will be really ugly to crawl on later and it will cut the plastic to shreds when you do crawl on it. Sand is probably a far better choice. On the plastic will help hold it from shifting when you crawl on it and you won't notice the layer of dust that will settle over time.
   / Taking a poll about crawl space vapor barriers #3
If you use gravel, use Pee gravel (size of BB's) instead of 57. Also be sure to use a very heavy plastic.
I did gravel, then plastic on top.
   / Taking a poll about crawl space vapor barriers #4
We used pea gravel, nice smooth edges, then the vapor barrier over top. I've never seen gravel on top of the vapor barrier.
Well $h!t!!! I have 10 tons of 57s in my back yard. Guess I gotta roll with it. No turning back now.
I have shifted gears a little bit and have decided to only do crawl space area where the plumbers will need to access under the bathroom. Probably ordered too much gravel, I guess I will bring it to my property and use it on the road. It needs it anyways.
   / Taking a poll about crawl space vapor barriers #6
You can never have too many 57s!
   / Taking a poll about crawl space vapor barriers #8
Plastic on top and yeah sand would be better. You want to be able to see the plastic to repair any tears that may come up. There are some very heavy plastics for this application. I'm thinking like 10 mil or greater.
   / Taking a poll about crawl space vapor barriers #9
I usually put sand in crawspaces. Gravel isn’t fun to crawl on.
   / Taking a poll about crawl space vapor barriers #10
Whoa! Gravel? Having been an HVAC contractor I would have walked the second I saw that. I ain't crawling on gravel. I put sand under my house and totally encapsulated the entire crawl space and have a de-humidifier under there. Keeps the humidity at 60% year round.
2014 TROXELL 130BBL VACUUM TRAILER (A50854)
2014 TROXELL...
2016 Sooner STC 9042 LQ Tri-Axle Horse Trailer (A49461)
2016 Sooner STC...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A49461)
2016 Ford F-150...
2019 BIG TEX GOOSENECK  TRI AXLE 34FT 2 CAR HAULER (A51222)
2019 BIG TEX...
2014 Volkswagen Jetta Sedan (A50324)
2014 Volkswagen...
1,000 Gallon Horizontal Fuel Storage Tank with Pump - Farm or Construction Ready (A51039)
1,000 Gallon...
