Takeuchi TL12V2 Quick Attach Problem
/ Takeuchi TL12V2 Quick Attach Problem #1
Quinc108
TakeuchiTL12V2
Only one circuit on my Quick Attach is working - by default the unlock switch works. To lock I have to switch the couplers that are midline between the switch and cylinder, press the unlock, and it will lock. I have tested continuity and everything is good from the switch forward - fuse is good, solenoid is good, switch is good, and the line is good all the way to the back of the machine and presumably to the relay box in the back. I'm Just not getting power to the lock side. I'm guessing a bad relay in the box in the back, but before I pull out the radiator to go back there I want to ask if anyone has encountered this or has any specific ideas direction regarding that box. Thanks!
/ Takeuchi TL12V2 Quick Attach Problem #2
I don't have any experience with your Tak but won't it be easier to start with the switch?
Good luck, that's a royal pita to go through just to change the attachment.
As I said in the post the switch is good. I tested it.
/ Takeuchi TL12V2 Quick Attach Problem #4
Dang speed reading. 😉
Not my first time. Have you asked on;
There's not a ton of ctl talk here in general, then machine specific makes it less likely. Hopefully you'll get lucky.
Thanks yes been meaning to do that but my login was not working. Got it
/ Takeuchi TL12V2 Quick Attach Problem #6
They dont use a standard relay? Either way I would try swapping relays. After that make sure your getting power from the switch and constant power on the high amp side. Of relay.
NEW Landhonor Diesel Fuel Transfer Pump (A62679)
NEW Landhonor...
429888 (A61165)
429888 (A61165)
2018 TAKEUCHI TL8 SKID STEER (A65053)
2018 TAKEUCHI TL8...
2019 ALLMAND LIGHT PLANT (A65643)
2019 ALLMAND LIGHT...
CHEVY 4X4 DUALLY TRUCK BED (A65643)
CHEVY 4X4 DUALLY...
2019 P.J. Trailer Trailer, VIN # 4P5F82029K1307542 (A65563)
2019 P.J. Trailer...
