Takeuchi TB145 excavator - need new hydraulic pump
   / Takeuchi TB145 excavator - need new hydraulic pump #21
Wow thanks! Really appreciate all the info.
So if my current pump is a clockwise rotation I can be confident the new Rexroth pump is the same? Looks clockwise to me on the little drawing on the Rexroth tag...
If the Rexroth nameplate shows a build date of 2011 Week 7 then its likely a reman (or just take off/paint) unit? How likely is it that a brand new pump from 2011 has been sitting around uninstalled for 8 years?
Thanks for the info guys. Its sounding more and more like this pump from the Alibaba vendor might work for me, at less than 1/2 the cost of one sourced in the US.
Blstr,
If reman it was not done by a Rexroth service center since they would have put a reman tag or some form of ID on it. Doubt sitting on the shelf since 2011 and if it has been you don't want it since the seals would potentially have dried out.
Yes, you are finding out that Rexroth product is not easily sourced outside of Rexroth distribution or the equipment OEM especially the Uchida division.
I have never used Alibaba so cannot comment on quality of rebuild.
   / Takeuchi TB145 excavator - need new hydraulic pump #22
hello, here attaches the instruction pdf for Variable double pump AP2D.
You can see that 28 and 25 means the Displacement Vgamx. and the word "R" means the Direction of rotation.
and after install the pump, the engineer will reprogram and the pump will work at a right displacement.
Hope this helps.
and if you need this pump, we can also supply, here is the link: https://www.fridayparts.com/hydraul...aewoo-doosan-excavator-solar-55-dh80-7-dh60-7
this pump also used for other excavator models.
  • Variable double pump AP2D.pdf
RHINO DB150 LOT NUMBER 73 (A53084)
RHINO DB150 LOT...
JOHN DEERE Z530M LOT NUMBER 77 (A53084)
JOHN DEERE Z530M...
2020 JOHN DEERE 7R210 LOT NUMBER 163 (A53084)
2020 JOHN DEERE...
UNUSED FUTURE QUICK ATTACH MAST W/ 29" FORKS (A51248)
UNUSED FUTURE...
CRAFTSMAN ZTS 7500 ZERO TURN LAWN MOWER (A51248)
CRAFTSMAN ZTS 7500...
Vactor RamJet Sewer Jetter Trailer (A51691)
Vactor RamJet...
