Takeuchi TB135 Oil Change - "Drain Connector"?
   / Takeuchi TB135 Oil Change - "Drain Connector"? #1
ctann
San Jose, CA
None yet
Hi all,
Gathering the parts for my first service of my 2007 Takeuchi TB135. I was looking at the Owner's Manual, and it calls out the need for a "Drain Connector" (15545-12600) in order to drain the oil. Is this something likely to be stored on the excavator somewhere? I didn't notice one, so I suspect it is missing even if it was there originally (it is an ex rental machine).
I did some web searching, but came up empty. Is this drain connector something I can make up myself? If not, can someone please point me to a source?
Thanks,
Chris.
   / Takeuchi TB135 Oil Change - "Drain Connector"? #2
if its like the one for a skidsteer probably have to get at dealer or talk rental place out of one
   / Takeuchi TB135 Oil Change - "Drain Connector"? #3
Hi all, Gathering the parts for my first service of my 2007 Takeuchi TB135. I was looking at the Owner's Manual, and it calls out the need for a "Drain Connector" (15545-12600) in order to drain the oil. Is this something likely to be stored on the excavator somewhere? I didn't notice one, so I suspect it is missing even if it was there originally (it is an ex rental machine). I did some web searching, but came up empty. Is this drain connector something I can make up myself? If not, can someone please point me to a source? Thanks, Chris.
It's a drain hose connector. You can just remove the adaptor from the block to drain the oil or like others have said, find one from dealer.
2014 INTERNATIONAL PROSTAR+ (A58214)
2014 INTERNATIONAL...
2016 Caterpillar 349FL Hydraulic Excavator (A56857)
2016 Caterpillar...
2007 International 4200 S/A Chipper Truck (A56858)
2007 International...
2018 Ford F-350 (A55973)
2018 Ford F-350...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
2017 Ford F-550 Chipper Truck (A56858)
2017 Ford F-550...
