TAFE 35DI Diesel Fuel System Problem Diagnosis and Troubleshooting...
   / TAFE 35DI Diesel Fuel System Problem Diagnosis and Troubleshooting... #1
Al Barrs
Bascom, Florida
TAFE 35DI
TAFE: 1994
Make: TAFE
Model: TAFE 35 DI
Engine Serial Number: S324 25367
Chassis Serial Number: B22774 M
My TAFE has begun losing power and will sit and idle but I can't increase the RPMs with the throttle, and it eventually just stops running at all. I have removed and cleaned the Fuel settlement bowl, bled the Primary and Secondary filters, and that got it running at 2200 RPM under the shed, but today I tried to use it and the same loss of power resulted. We don't have any tractor dealers in my county that will work on TAFE tractors, and of course they don't make TAFE anymore, but the TAFE factory in India does manufacture Massey-Ferguson tractors. The TAFE 35DI is a clone of the old Massey-Ferguson 35D diesel.
Has anyone had this problem and how did you correct it, if you did?
I don't want to screw anything up with the diesel fuel injector pump because I just spent over 800 dollars three years ago to rebuild it. Any suggestions?
Thanks,
Al Barrs
Quail Ridge Farm
Jackson County,
Greenwood, FL 32443
albarrs@wfeca.net
I found my trouble with my TAFE 35DI diesel fuel system. Apparently all the jostling while I was scraping hurricane debris and gouges from the excavator jarred the fuel settlement bowl lose enough it was sucking in air, but wouldn't leak any fuel out. I just started at the beginning of the fuels system and removed, cleaned, reinstalled and bled the fuel system--it started right up, but don't know if that was the real problem or not until I put it back to work tomorrow... Thanks to all who made suggestions to me...
Al
   / TAFE 35DI Diesel Fuel System Problem Diagnosis and Troubleshooting... #3
Keep on truckin' Al..
2019 Chevrolet Malibu , VIN # 1G1ZC5ST5KF136071 (A51572)
2019 Chevrolet...
2023 Ford Explorer AWD SUV (A51694)
2023 Ford Explorer...
2017 Ford 550 XL, Cab and Chassis, Crew Cab (A52384)
2017 Ford 550 XL...
New/Unused 72in Quick Attach Skid Steer Mulcher (A51573)
New/Unused 72in...
New/Unused 7ft 20 Drawer Stainless Steel Workbench (A51573)
New/Unused 7ft 20...
2005 Ford F650 SVI Crew Cab Hazmat Truck (A52377)
2005 Ford F650 SVI...
