TAFE 35DI Diesel Fuel System Problem Diagnosis and Troubleshooting...
   / TAFE 35DI Diesel Fuel System Problem Diagnosis and Troubleshooting... #1
Al Barrs
Bascom, Florida
TAFE 35DI
TAFE: 1994
Make: TAFE
Model: TAFE 35 DI
Engine Serial Number: S324 25367
Chassis Serial Number: B22774 M
My TAFE has begun losing power and will sit and idle but I can't increase the RPMs with the throttle, and it eventually just stops running at all. I have removed and cleaned the Fuel settlement bowl, bled the Primary and Secondary filters, and that got it running at 2200 RPM under the shed, but today I tried to use it and the same loss of power resulted. We don't have any tractor dealers in my county that will work on TAFE tractors, and of course they don't make TAFE anymore, but the TAFE factory in India does manufacture Massey-Ferguson tractors. The TAFE 35DI is a clone of the old Massey-Ferguson 35D diesel.
Has anyone had this problem and how did you correct it, if you did?
I don't want to screw anything up with the diesel fuel injector pump because I just spent over 800 dollars three years ago to rebuild it. Any suggestions?
Thanks,
Al Barrs
Quail Ridge Farm
Jackson County,
Greenwood, FL 32443
albarrs@wfeca.net
I found my trouble with my TAFE 35DI diesel fuel system. Apparently all the jostling while I was scraping hurricane debris and gouges from the excavator jarred the fuel settlement bowl lose enough it was sucking in air, but wouldn't leak any fuel out. I just started at the beginning of the fuels system and removed, cleaned, reinstalled and bled the fuel system--it started right up, but don't know if that was the real problem or not until I put it back to work tomorrow... Thanks to all who made suggestions to me...
Al
   / TAFE 35DI Diesel Fuel System Problem Diagnosis and Troubleshooting... #3
Keep on truckin' Al..
1/2'' Wolverine Universal Quick Attach Mount Plate (A51573)
1/2'' Wolverine...
JOHN DEERE 5115M TRACTOR (A51243)
JOHN DEERE 5115M...
1992 Ford F-150 Pickup Truck, VIN # 1FTDF15Y3NNB06697 (A51572)
1992 Ford F-150...
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A52377)
12-Wheel Pneumatic...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
