Tachometer
/ Tachometer #1
Mac53
Cubcadetyanmarsc2450
The tachometer stopped working. Is tach electric (fuse blown?) or possibly tach cable end broken? Thanks
/ Tachometer #2
What have you done to see if you can find out what's wrong?
willy
/ Tachometer #3
Depending on make, model, and year of tractor tachometer and hour meter may be electronic and driven by input from tachometer. Many times if there is an alternator problem the tachometer operation is the first sign. I would test for charging voltage at battery with tractor running. If it's showing 14.0-14.2 volts then alternator and regulator is working properly. If that's okay then check wiring from alternator to tachometer. If that's okay and your hour meter is recording engine hours when it's running your tach might be defective. Wiring diagram can help you trace the circuits to check if needed.
PREVIEW DATES AND TIMES (A65579)
PREVIEW DATES AND...
CATERPILLAR TL642D TELESCOPIC FORKLIFT (A62129)
CATERPILLAR TL642D...
2014 International WorkStar 7400 T/A VacCon VPD4211 Combination Sewer Jetter Vacuum Truck (A61573)
2014 International...
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
Caterpillar 215 Excavator Parts and Service Manuals (A63117)
Caterpillar 215...
(2) 380/85R28 TIRES W/ (10) LUG WHEELS (A64280)
(2) 380/85R28...
