Tachometer
   / Tachometer #1
Mac53
Cubcadetyanmarsc2450
The tachometer stopped working. Is tach electric (fuse blown?) or possibly tach cable end broken? Thanks
   / Tachometer #2
What have you done to see if you can find out what's wrong?
willy
   / Tachometer #3
Depending on make, model, and year of tractor tachometer and hour meter may be electronic and driven by input from tachometer. Many times if there is an alternator problem the tachometer operation is the first sign. I would test for charging voltage at battery with tractor running. If it's showing 14.0-14.2 volts then alternator and regulator is working properly. If that's okay then check wiring from alternator to tachometer. If that's okay and your hour meter is recording engine hours when it's running your tach might be defective. Wiring diagram can help you trace the circuits to check if needed.
Komatsu WA180-1 Wheel Loader (A47477)
Komatsu WA180-1...
1995 Rinker Captiva 190 (A55218)
1995 Rinker...
2019 Allmand Bros Maxi-Lite 2V 15W S/A Towable Light Tower (A52377)
2019 Allmand Bros...
2017 Hitachi ZX245USLC-6N (A47477)
2017 Hitachi...
Hose Reel (A53424)
Hose Reel (A53424)
JOHN DEERE 1700 LOT NUMBER 17 (A53084)
JOHN DEERE 1700...
