Tachometer Problem
/ Tachometer Problem #1
jhaynes
Vicksburg, MS USA
Kubota L3010
I removed the dash from my l3010 to check the bulb on the engine oil pressure light. I had to remove the tachometer cable from the back for easy access. When I installed the cable back on the back of the dash, it now reads around 2000 rpm at idle and is bouncy; it was reading less than 1000 before removal. I have removed and install several times and still have same problem. Any suggestions
/ Tachometer Problem #2
I would bet the cable is not properly seated either at the tach or at the drive head on the engine.
Thanks kuboman for the reply, beginning to think I was the only one to ever have this problem. I will try that; is it difficult to seat it at the drive head on the engine?
Thanks,
/ Tachometer Problem #4
I recently had a problem with a cable-drive speedometer (Triumph M'Cycle) where it indicated erratically or sometimes not at all, because when I screwed the outer cable ring nut on all the way snug, the inner cable was actually too far into the speedo drive and jammed things up. So you might also try backing the ring nut off a few turns to see if that makes a difference. On my speedo, I stuffed an appropriately sized o-ring down into the ring nut so that it couldn't thread on quite as far.
- Jay
2006 KOMATSU PC300LC-7 EXCAVATOR (A62129)
2006 KOMATSU...
2014 Ford F-550 Altec AT40M 40ft Material Handling Bucket Truck (A61568)
2014 Ford F-550...
1981 LINK BELT HSP 8028 (A58214)
1981 LINK BELT HSP...
Eagle Weathervane (A61569)
Eagle Weathervane...
Redirective Crash Cushion Guardrail (A61568)
Redirective Crash...
2019 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A60352)
2019 GMC Sierra...
