tach sensor
   / tach sensor #1
slammer3364
Bronze Member
Jinma 284
put a new tach sensor on my 284Jinma,put it on did not register,screwed it in a little further and the tach reads and the hour meter works. The problem is the tach meter don't seem to read right,is ther anyway to calibrate. Thanks Slammer
   / tach sensor #2
If the sensor is a generic type, they are usually screwed in until it touches the flywheel and then backed out about 3/4 turn and locked there. I expect Tommy at Affordable might chime in on this. My comments are based on adjusting/setting up other tachs.
If your tach is like the one on my Jinma, there is a plug that connects to the harness on the tractor - make sure it is properly connected.
   / tach sensor #3
We use this TIF TIF785 Infrared Photo tachometer, to adjust ours, however if you don't want to spend a $ 150.00 for one, you need to screw the sensor in until it touch's and back out 3/4 turn as Jim suggested. You should be close to the correct RPM. Otherwise you will need to get a meter or see if someone has one you can borrow
Tommy
Affordable Tractor Sales
"Your Jinma Parts Superstore"
Home of compact Jinma, Foton, and Koyker Tractors and Parts, Wood Chippers, Backhoes - Affordable Tractor Sales Company
2013 Ford F-250 Pickup Truck (A51692)
2013 Ford F-250...
2024 JOHN DEERE 1025R LOT NUMBER 106 (A53084)
2024 JOHN DEERE...
2012 Ford Explorer (A50123)
2012 Ford Explorer...
2005 Caterpillar 430D 4x4 Extendahoe Backhoe Loader (A51691)
2005 Caterpillar...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2005 Manac AAF-48 50 Ton Flatbed Equipment Trailer (A51692)
2005 Manac AAF-48...
