Tach not working
   / Tach not working #11
I ran a ground wire from the battery last night to what I think is the ground for the tach with no luck. I can't help but think it's something simple but I'm stumped. I'm not ruling out a grounding problem either.
View attachment 607612View attachment 607613
You may need to look over all of the connections in the Dash area, not only the dash connection what about the frame ground in that area, you did say a few of the gauges were having problems... so you need a common point for all gauges... i.e. GROUNDS or power !
Disconnect, clean, and reinstall all of the gauge connectors, put some conductive electrical paste on the connections and a little in-between the Nut, Lug, and Mounting Point !
Electrical problems are a hard thing to follow and fine, some maybe not even related to the source of the problems. I had a Mustang with Fog Lights, I got a short where my tail lights and license plate lights were on all the time. I went though the drill on the rear of the vehicle thinking taillights, and couldn't find the problem. I broke down and took it to a local electrical shop and WHAM-BAM he found a shorted wire in my Fog Light Switch.
How did the Fog light Switch effect the Taillights, not sure but the problem was done with. So I am thinking are there any other electrical problems, that pop up once in a while, small ones, you may not think they are related but you will only know when they are fixed !
After reading a related post, your tach runs off the alternator, is the alternator working ok, putting out as needed ?
Also, do the gauges that sometimes don't work, not work together or at different times ?
Ltr
   / Tach not working #12
I would pull all those screw terminals on the back of the cluster one at a time and clean them and tighten. Those 3 terminals in a triangle pattern are the back of the gauge motor. Could be an issue. I would do that to all terminals first. Then you need a multimeter to start checking the inputs to each gauge. Not sure what the schematic shows, but each gauge should have a power + and - and a signal wire.
   / Tach not working
Well as mysteriously as it stopped working... it started back working again yesterday. I still plan on taking each screw out and cleaning it then applying some dielectric grease as it goes back together.
   / Tach not working #14
Since it works , then not, then it does again... it is either one of two things... :
1) Electrical Connections that the thread has touched on.
2) the Tach is broken inside with intermittent connections.
If this happens again you should consider either replacing the Meters that don't work or take apart the meters that don't work and see if you can find a bad connection or something else that maybe wrong.
Intermittent Electrical problems can be a bear to locate.
Good Luck !
   / Tach not working #15
Our 6200 had an intermittent tach. It has the magnetic sensor up front somewhere, which was replaced and has been working well for years. I would not have thought, that would be intermittent as it's just a coil of wire.
INGERSOLL RAND SD-100D SMOOTH DRUM ROLLER (A52707)
INGERSOLL RAND...
Ratchet Straps (A55852)
Ratchet Straps...
2021 Kubota RTV X900 4x4 Utility Cart (A55787)
2021 Kubota RTV...
UNUSED SDLANCH SDLL80 LOADER (A57192)
UNUSED SDLANCH...
2014 Nissan Murano SUV (A55853)
2014 Nissan Murano...
2025 IRET 13 Utility Electric Tricycle (A55853)
2025 IRET 13...
