tach meter
   / tach meter #1
slammer3364
Bronze Member
Jinma 284
Had my Jinma 28 to the mechanic,say (he called it a tach sensor).Screws into engine block, must read the fly wheel. Is this the correct name of part?
   / tach meter #2
Technically it's a reluctor but the slang terms are "mag pickup" or "tooth counter".
   / tach meter
Thanks Bob appreciate it going to see if I can order part Mon.
   / tach meter #5
I kinda hopping on this thread with a little different question on a JM 354. My tach consistently reads at High Rpm 1600. I'm not sure whether the fuel pump is just not getting the engine to rev up (2200) or my tachometer has a bad component? Any suggestions? bjr
   / tach meter #6
   / tach meter #7
You can verify the tachometer's accuracy with a photo-tach, if you have one. Got mine at Harbor Freight.
   / tach meter #8
I just bought a 2004 JM284LE, and my tachometer is not functioning. Is it safe to assume that this is function of a sensor and not a cable?
Thanks J
   / tach meter #10
Tommy
Thanks again, I know who I will go to for parts.. This is a bit off topic, and I asked this question in a different thread. I am leaking hydrolic oil out of the vented filler plug, this seems to only be a problem when going up a steep incline. Is this symptomatic of anything other than gravity...?
Thanks ..J
AGT Mini SkidSteer (A50322)
AGT Mini SkidSteer...
2025 SDLANCH SDLE18P UNUSED Mini Excavator (A53117)
2025 SDLANCH...
BUYERS PREMIUM & PAYMENT TERMS (A54313)
BUYERS PREMIUM &...
1267 (A50490)
1267 (A50490)
2017 Land Rover Discovery SUV (A51694)
2017 Land Rover...
2022 Club Car Tempo Cart (A51694)
2022 Club Car...
