Tach and hours odometer inop
   / Tach and hours odometer inop #1
Graystoke
2005 DK35
I have a 2005 DK35. The tachometer and hours meter stopped operating. Visual inspection shows nothing loose. I am Looking for some advice as to what I should be looking for. Interested in any ideas or experience.
   / Tach and hours odometer inop #2
Not completely sure how its being driven, but both could be operated by a magnetic pickup... if so, it would most likely be screwed into the rear housing of the engine... IF it uses this type of setup, simply unscrew it, clean the debris off the end, screw it back in until it stops, then back it out approx. 3/4 turn and tighten it down...
But, I am not familiar with Kioti, so it may not use this setup...
Thanks. I will start there
   / Tach and hours odometer inop #4
Check you tach cable. I'm betting it broke.
The older style DK 35 used a cable for the tach/hourmeter.
   / Tach and hours odometer inop #5
aaahhh... i forgot about old cable drives!!!!!...
PALLET OF 12IRON GATES (A58214)
PALLET OF 12IRON...
2010 KENWORTH T800 (A58214)
2010 KENWORTH T800...
2012 International Prostar (A56435)
2012 International...
2014 Ford Taurus AWD Sedan (A54815)
2014 Ford Taurus...
2013 Dodge Durango (A53317)
2013 Dodge Durango...
2021 Polaris Ranger Electric Utility Bed UTV (A56859)
2021 Polaris...
