TA: mech or hydraulic shuttle
   / TA: mech or hydraulic shuttle #1
case685
Southwest Ont. Canada
Hi Been looking at an Iseki TA357F. Just wondering if anybody could answer a couple ?s I have. First, is the shuttle on the column mechanical or hydraulic. Also this tractor appears to be quite close to a MF 1160 in size, age and specs. Would this be a possible crossover or would parts only be available for this machine from Japan. Thanks
   / TA: mech or hydraulic shuttle #2
I have a TA 207 and have had TA210,255,270 . They all were mechanical. You have to clutch to shift. It will " grind " if you don't have the RPM right when you shift after it has set with it out of gear for a while. You can shift transmission gears while moving, 1,2,3,and 4. As far as cross over it is too big for any info I have.
   / TA: mech or hydraulic shuttle #3
Mechanical.
closer to the 1200 series massey
Buck
   / TA: mech or hydraulic shuttle #4
My TA247 is nearly identical to a Massey 1240. I have looked both over very carefully. " Nearly " Identical. Im guessing yours would be " Nearly " a 1250.
Good Luck..
2024 JOHN DEERE 331P-TIER SKID STEER (A51246)
2024 JOHN DEERE...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A52748)
NEW HOLLAND 706 30...
2018 Club Car Carryall 500 Electric Utility Cart (A51691)
2018 Club Car...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
2021 KUBOTA SVL75-2 SKID STEER (A51246)
2021 KUBOTA...
toro turf sweeper (A50324)
toro turf sweeper...
