TA: mech or hydraulic shuttle
   / TA: mech or hydraulic shuttle #1
case685
Southwest Ont. Canada
Hi Been looking at an Iseki TA357F. Just wondering if anybody could answer a couple ?s I have. First, is the shuttle on the column mechanical or hydraulic. Also this tractor appears to be quite close to a MF 1160 in size, age and specs. Would this be a possible crossover or would parts only be available for this machine from Japan. Thanks
   / TA: mech or hydraulic shuttle #2
I have a TA 207 and have had TA210,255,270 . They all were mechanical. You have to clutch to shift. It will " grind " if you don't have the RPM right when you shift after it has set with it out of gear for a while. You can shift transmission gears while moving, 1,2,3,and 4. As far as cross over it is too big for any info I have.
   / TA: mech or hydraulic shuttle #3
Mechanical.
closer to the 1200 series massey
Buck
   / TA: mech or hydraulic shuttle #4
My TA247 is nearly identical to a Massey 1240. I have looked both over very carefully. " Nearly " Identical. Im guessing yours would be " Nearly " a 1250.
Good Luck..
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A51222)
2006 CHEVROLET...
2005 Hino 268 Truck, VIN # JHBNE8JTX51S10984 (A51572)
2005 Hino 268...
20' Multi Door One Way Ship Container (A52384)
20' Multi Door One...
2010 Chevrolet Impala Sedan (A51694)
2010 Chevrolet...
