T6 upgrade to twin cylinder loader
   / T6 upgrade to twin cylinder loader #1
agjones
Platinum Member
Jessup Mill, NC
Rk55HC, Kubota kx040, power-trac 425d, Bobcat L23, Yanmar 401w, bx1880, IHI 30 and Fiori D40 dumpers, Magnatrac mh5000, Dew-eze ATM72LC Slope Mower, Terramite t6 4wd, DR Power brush mower
Hi all
I recently upgraded my T6 1998 to the dual loader bucket cylinder like terramite went with on the t9. Just thought I'd share a picture.
I'd already replaced the bucket with a skidsteer tilt setup from Titan. So I've got 15+deg side to side like a 6way blade. And can pick up any skidsteer attachments.
   / T6 upgrade to twin cylinder loader #2
Nice work. Did the T6 use a single cylinder for lower cost? What are the befits of a dual cylinder loader?
Thanks, a little plumbing left to finish.
I don't know why the T6 had a single cylinder. 2 years after mine was made they redesigned went to two cylinders and called it t9.
I changed the loader geometry when I added the tilt plate (400#) and it was clear one cylinder was no match for the setup.
   / T6 upgrade to twin cylinder loader #4
One cylinder can work, just needed to be a larger cylinder
Lots of big machines have a single cylinder for the bucket.
Aaron Z
Absolutely. I see big front loaders w single cylinder set up all the time.
In my set up, I was leaning toward two because of the tilt function shifting weight, and the unbalanced pushing force on the loader arms when digging w a tilted bucket.
Plus I was having a hard time finding a single big cylinder affordable and right sized. Two perfect size (for dual) fell in to my lap for 40$ each. I can make my own hoses so that was the end of the search...
   / T6 upgrade to twin cylinder loader #6
Sounds like a great solution for your situation.
Aaron Z
2018 PJ TRAILER 32FT GOOSENECK TRAILER (A55745)
2018 PJ TRAILER...
2009 Pontiac G6 Sedan (A55853)
2009 Pontiac G6...
20 UTILITY TRAILER (A55745)
20 UTILITY TRAILER...
2016 Chevrolet Tahoe SUV (A55853)
2016 Chevrolet...
2025 Star EV Capella Low Speed Electric Cart (A55853)
2025 Star EV...
2013 Ford Fusion SE Hatchback (A55853)
2013 Ford Fusion...
