T5C Hydraulic oil drain plug?
   / T5C Hydraulic oil drain plug? #11
I bought the seals at a hydraulic place in the city nearby. It's really worth it to locate the best (not necessarily the nearest - unfortunately) because you develop a relationship with them and if they're not too big, they will help you out. I brought in the seals on a ring (at their request), and they worked off of them because they're pretty standard. Once you get a cyl apart, you'll find 3 rings on the piston end (two large around the outside of the piston end, and a small O-ring under it, and 4 or 5 on the gland end (the end that has the spanner holes. The outer seal is called the wiper and is pretty standard. Then on the inside and outside of the gland, there will be the gland seals, usually an O-ring with a spacer beside it. If you ask them to try to find the equivalent one piece seal for the inside groove that will replace the O-ring and spacer, they may find it for you and it's a more reliable seal. Costs a bit more but well worth it. Costs can be around $20 + or - for the bunch.
Then too they will make up replacement hyd hoses - often while you wait; they're expensive .60 an inch and $8 for end fittings. but they last many years and eliminate the drips and blown hoses in the middle of a job. Save the best long one for an emergency spare.
Hope this helps. . . .
Unless the retaining wire is shot, you can reuse it. Someone suggested getting a length of 1/8" copper coated wire from a welding shop and making your own 90 degree hook on the end. The square steel retainers they sell commercially can be tight (or impossible) to install and they are expensive.
If you want I can send you a pix of the spanner wretch I built. With a little filing, it has fit so far, but I understand it may not work on the big (?) ones.
   / T5C Hydraulic oil drain plug? #12
Hope you are aware that these tractors DO NOT use a standard hydraulic oil. They use a multi vis. motor oil in the hydraulic system.
   / T5C Hydraulic oil drain plug? #13
Yes, I'm using 10-30 and keeping it in the garage there's been no starting issues. Previous owner kept it outside so I'm guessing that took its toll on seals. I'd sure like to hear from anyone who has removed the swing cylinders; so far can't budge the pins from the upper side, and too cold to try anything from the underside.
   / T5C Hydraulic oil drain plug? #14
Alan I have replace mine on my t-3-15 yes they can be a bear to get out. I had to use a air chisel to get mine out. I'm assuming the t5 has the pins going up to remove you can purchase a cheap air chisel from walmart or Harbor freight just put it at the center pull the trigger it should come out. make sure you clean the pins real good when reinstalling them and grease.
Sam
   / T5C Hydraulic oil drain plug? #15
Sam; Thanks for the reply; Yes mine are vertical - the top flange is on the floor under the seat, and then down thru the cylinder and through the lower flange on a steel plate below. They go up to remove. So you put the air chisel under the pin from down below to hammer up? You must have used a blunt end rather than the chisel to keep from cutting the end of the pin? Or are you using the chisel as a pry from the top side, prying under the steel strap that bolts the pin in place?
   / T5C Hydraulic oil drain plug? #16
Yes from down below and I used the chisel end didn't hurt the pin a little maring but nothing serious. just push's the pin up. Not as pry bar. came out pretty easy when i did it. you can get replacement cylinders from DaltonHydraulic.com if you need them I think they were 65.00 each at the time(last Year) Good Luck
Sam
   / T5C Hydraulic oil drain plug? #17
So today I decided to change the hydraulic oil in my newly acquired T5C. I can't find a drain plug or valve to empty the tank.
I finally took off the hydraulic filter to drain the oil. Am I missing a plug somewhere? Looks to me like draining it this way leaves 1/2" or so of old oil but I can't find a plug in the bottom of the tank
Also does anyone have any maintance information on the T5C. Like pictures or drawings showing where drain plugs, grease zerks etc. are located? I think I have seen everything on the Terramite website.
Pat
You can drain all of the reservoir by removing the hose on the opposite side of the tank that goes to the tranny.
2000 Ford F-150 Ext. Cab 4x4 Pickup Truck (A53422)
2000 Ford F-150...
40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
40ft T/A Gooseneck...
2020 Exiss Escape 7306 LQ T/A Gooseneck Horse Trailer (A50322)
2020 Exiss Escape...
2016 Ford Explorer AWD SUV (A53424)
2016 Ford Explorer...
Booster Cables (A55852)
Booster Cables...
2023 Kubota LX2610SUHSD MFWD Compact Tractor with LA535 Front Loader (A55314)
2023 Kubota...
